Results 1 to 20 of 40
    Power Head Will Not budge
    Unhappy
    All of the bolts are out, I suggested heating it up with a torch. My mechanic wants to lift it with one of our fork trucks
    Registered DollaBill's Avatar
    you'll prob need both. leave the transom mounting bracket attch'd to the boat and use the forklift to pull (gently) on the powerhead. be careful heating it up before and during the pull. what brand and year?
    Do you have the lifting ring that screws in the flywheel? The long studs like to get stuck. If so pull away. It may lift the boat first. Collect so little puck like things and / or stacks of washers so you can use the nuts to help push the studs up. A proper jesus bar will fit across the tiller arm to pry upward on the 2 forward studs. Hopefully you can get it loose enough to rock back and forth a little then heat the on that needs the persuasion. DO NOT drive wedges in where the powerhead gasket is. I have even cross drilled the long studs out in the exhaust plate before.
    Its at least a 6 pack job when stuck tight. My bad one took a 12 pack.
    I have also used an air hammer on the end of the studs to knock them loose. You will find corrosion all up and down them when you get it loose. I have also lifted the back of a 7000 lb boat before they came loose so be prepared.
    YES. I took for granted he was using a lifting ring bolted to the flywheel
    Forgot about this, I have never had one last long enough to get stuck, blew the first one, then sold the next two to upgrade
    I have the lifting ring on the flywheel, went down to get the forklift and someone was using it without permission ( permission is a couple gallons of diesel and an 18 pack of Bud Light) So I'll have to wait til tomorrow.
    well then all you can do is start drinking now and get your thoughts together for the morning
    Contributor Davidmnc's Avatar
    Carolina Beach, NC
    Quote Originally Posted by DollaBill View Post
    The Penguin Cometh
    WAAAAAAY ahead of you gentlemen !
    Serious is the BOMB!
    We want video of this adventure......
    Registered Trim'd Up's Avatar
    STL, on the ILL side
    Try a chainsaw!
    Burrito Springs Florida
    Have you had the lower unit off recently. If not the shaft maybe stuck in the crank. Had it happen not fun you have to hole saw a hole in the midsection and heat up the shaft or cut it if its really stuck.
    Bob, go to the drugstore and buy a dozen of those pop and shake cold paks. Carefully cut them all open and place the white powder inside in a ziplock freezer back. Now put some deisel fuel in and mix untill you have a slurry. Place 1 blasting cap inside and tape the baggy around the stuck area then duck, yell Phragle rules! and it should then be in at least 2 pieces.
    Carolina Beach, NC
    Some guys in black suits just stopped by asking questions about you. They said they were from home land some thing? I told them you were nuts and they left headed up 77 pretty fast.
    The Penguin Cometh
    Thanks for the heads up... I will put on my Penguin disguise and they will never recognize me.
    Apr 2009
    were they wearing dark shades,,,
    Were these the guys??
    Apr 2009
    close your eyes and don,t look,,
    Apr 2009
    sorry bobcat,,were phoquen up your thread..
