Results 1 to 18 of 18
    GlassDave earns his Bat Cape
    Temple, PA
    Hats off to GlassDave for hauling his azz over here to PA and overseeing a tricky project on my Batboat. I couldn't be happier with the way the whole thing turned out, and we all had a few laughs along the way. I'll leave it to Dave to post his favorite shots, but some of the details are already posted on the Ilmor 725 thread in General Discussions.
    Thanks, Dave!
    registered
    Edgerock, MD
    Thumbs up
    Dave is one of the good guys!!!
    Charter Member jet's Avatar
    toledo
    good job buddy see ya at lunch
    beer is food
    on the moon . . .
    Thanks Chuck glad i could help out. It was good to put our heads together to come up with a solution to a somewhat technical and out of the ordinary rigging situation. Cant wait to get a ride in that rocket ship at jammin on the james.
    Again thanks for the hospitality glad i could help the project.
    Attached Thumbnails Attached Thumbnails C spray batboat 026.jpg   C spray batboat 032.jpg   C spray batboat 027.jpg
    Homeless in West Mich
    You bag man and to think no chesse.
    hay dave are trying to draw mickey mouse on the back of that boat : good jop . nice project. cant wait to see wt you do next
    With the vacuum bagging on both sides of the transom, how is the outside kept flat and smooth?
    on the moon . . .
    Its all in the setup. When i got there the first thing we did was to bond in a first piece that was the exact size of the original hole but only about 5/8th inch thick. The existing fiberglass and wood was cut back and recessed and "shelf" in two new inner and outer pieces that were bagged on. The first bonded in piece effectively gave us a solid platform to work out from. Bagging transoms can be very tricky, you never know how it was done originally and leaks can come from anywhere. I had one persistent air leak on this one that came from an old bilge pump mounting hole that i missed. Had to find and isolate it quickly.
    The outside was also kept flat by carefully cutting the laminates to match the scarf as best you can. We got really close on this one. Chuck put a few miles on my Kevlar shears
    Attached Thumbnails Attached Thumbnails transom2.jpg   C spray batboat 011.jpg   C spray batboat 016.jpg
    Thank you for that explanation. I appreciate the detail.
    Eric
    Dave , i really like that graph .
    on the moon . . .
    Nice touch huh . . . . feel free to print one out for yourself Artie
    Temple, PA
    Hey, Dave - If you come back over this weekend, I'll pay you in tacos and margaritas do all the grinding and leveling...
    toledo
    Good deal for you C Spray,if I was the glass guy that would cost you a bunch..................offer Dave Little debbies and club soda,I bet that will be a deal lol (sorry dave its an open forum lol)
    beer is food
    Temple, PA
    Here's a section of the finished transom. THAT ought to do it...
    Attached Thumbnails Attached Thumbnails 20100404_Cutout (Large).JPG   20100404_Cutoutb (Large).jpg
    on the moon . . .
    what did you cut that out with? Looks like a clean cut.
    Temple, PA
    Router (!!!) and a 1/4" x 2" spiral cut carbide bit. (Just like the prep work.)
    on the moon . . .
    oh yea . . . . forgot about that. No prob with the Kevlar then huh. What brand and part number was that bit? Gonna hafta get me one of those.
    Temple, PA
    It wasn't happy with the Kevlar, but the hole is cut, so I guess the bit wins.
    Bosch #85911MC, 1/4" diameter x 1" cut length Upspiral straight bit. About $20 from Lowe's. It's 2-1/2" overall, so if you pull it out to cut through 2", there's not much left in the collett, and the vibration tends to make it walk out. If I can find a longer one, I'll let you know. I'm in the market for one, after I knocked the router off of the bench and shattered my bit.....
    McMaster numbers:
    27395A95 ($21.75): 2-flute, 2-1/2" long, the same as I used
    8711A11 ($49.85): 3-flute, 3" long
    3334A13 ($79.73): Diamond pattern, 2" long, specifically designed for cutting carbon
    8785A24 ($14.12): Diamond pattern, 2" long, specifically designed for composites
    8796A12 ($36.95): 40-grit diamond coated, 2-1/2" long, for composites and ceramics.
    The last one (8796A12) is probably the best choice.
