Results 1 to 5 of 5
    Carb rebuild question
    Traverse City, Mi
    I have stock 7.4 Mercruisers with the Weber carb. Mercruiser p/n is 3310-806969a1.
    Does anyone have the Carter part number for these carbs ? I want to do a rebuild and was told NAPA carries the kits under a Carter part number.
    ed
    Traverse City, Mi
    After doing some more searching it appears this is now a Carter to Weber to Edelbrock carb. Could someone confirm that and does anyone know the rebuild kit part number ?
    ed
    Charter Member Griff's Avatar
    Omaha NE
    The Carter AFB, Weber and Edlebrock are all the same basic carb and use most of the same parts. The stock Merc carb is 750cfm.
    Traverse City, Mi
    Griff,
    So I can use a Edlebrock 750 cfm rebuild kit ?
    Omaha NE
    Never tried it so I do not know for sure. I don't what changed between the Carter, Weber and edlebrock, if anything really. I only had one Weber and I replaced it with a Holley. The Webers were notorious for hard cold starts due to internal leaks in the fuel bowls.
