Results 1 to 8 of 8
    525 closed cooling pink stuff?
    Tampa Area
    Where can I get some closed cooling system coolant to top off the reservoirs?
    North of tampa. Most marine stores here have no clue what I'm talking about.
    Is that RV coolant stuff the same?
    Thx
    P
    Charter Member Griff's Avatar
    Omaha NE
    The coolant is just Dex Cool antifreeze. You can get it at any automotive store.
    It is not the the RV pink stuff.
    The RV pink stuff is antifreeze only.
    ________
    Tampa Area
    ok.. RV stuff antifreeze only. and ? is the Dex cool 50/50 or something? Can't I just add regular antifreeze to top off?
    I really don't know whats in it, but I don't want to add something I can't.
    Thx
    P
    Stockholm, Sweden
    Don't mix colors and you're good to go. Get some red anti freeze at your local auto store.
    28 F1 Pantera - Sit down and foot throttle | DPM Drive
    Tampa Area
    Got the Dex Cool. Made for GM's, it's redish, so I think I'm good. I only needed a little.
    Thanks guys.
    P
    Registered Big Time's Avatar
    Stamford, CT
    I always keep a bottle of this around just for topping off (although haven't had to use it yet): http://www.mercurypartsexpress.com/u...ze-p29153.html
    If you are just topping off you should be fine with any red/orange 50/50 mixure.
    Registered 35 Lightning's Avatar
    Aug 2009
    Southern, IL.
    don't mix the dexcool with green anti freeze, may cause alot of problems.
