Yea, boating in the rain sucks. We usually just put the cover on and wait it out. After I thought about it I did have one time last year I had to boat back in the rain. The rain set in and it was not clearing off. Last year we got rained on about 8 or 9 times, not a good boating year weather wise.
Thread: Ram Air / Air intake
Results 21 to 40 of 113
03-19-2010 12:12 PM
03-19-2010 06:14 PM
Here are a few more pictrues of the inner vents. This is very time consuming work, not for the impatiant person. Almost finnished with this part.
03-19-2010 09:45 PM
Good question, I will be removing the snaps soon. I will need to re gel some of that area anyway so I was not real worried about it. I should have waited till next year for this one, turned into a much bigger project than anticipated. I am going to have some gel color matched to the vents. So the area behind the vent and the new glass will get gel also. I have a lot of wasted time with trial and error I think I am on the right track now.
03-20-2010 09:05 AM
I believe this also to be a true statement.. I checked that out when working with NorTech on doing that to my 43..they have actually blocked some of the air out..scoops were to big..and where air exit out could have been made larger. Next boat that Im working on will have some flush mounted inlets somewhere in front before the windscreen that channels down the first step for ariation.. Good luck with your project..
03-20-2010 09:45 AM
All of the air from the vents will be forced directly into the TB. I have the Holley MPI kit with the 1000CFM billit TB that uses the standard size carb opening. Specter makes a air box with dual 4" inlets that should work perfect. The bilge will still be vented by the other holes on the back.
- Where the summer never ends
- 4,346
03-20-2010 05:35 PM
Here are the latest pics. I took some of the inside to show the mounting flange for the air ducts and the vents on the back of the boat. The bilge connects to one side and the other draws in the fresh air.
- 37,345
03-20-2010 05:48 PMYou are fine except you do need to make sure you have a system for not getting water in the TB. Either don't go direct to the TB, or build a box as Ted said.
The biggest loss of potential HP comes from the engine room being hot, not from the lack of pressure. However, some compartments do not have enough air for the amount the engines require at WOT.
If I were you, I'd run it without the direct connection to the engine and just try to somewhat have positive pressure in the engine compartment and enough air so ambient outside temperature is maintained.
I think you're on the right track, just would not take the chance of water ingestion into the TB.....Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
03-20-2010 06:19 PM
Thanks for the input, I run the bilge all the time so that should keep it ventalated. I am going to wait till later in the season to put the air cleaner and ducts in. Way over budget on the projects this winter. I am still thinking about the water protection issue. I will come up with somthing.
03-20-2010 09:48 PM
Ok Artie, I removed the snaps and cleaned up the crap off of the glass, I hope that makes you feel better. I should have taped it off, I figured it would come right off because that part still had wax on it. So what do you think about this little project do you think it will be worth the effort? From the amount of labor involved I am not sure if I will be recomending it. Depends if I gain anything HP or fuel economy wise.
03-22-2010 09:13 PM
Here are the latest pics. I changed the color of the stripe that is in front of the vent. Well now there is no stripe, the vent will be white also. Still needs sanded and buffed.
03-26-2010 05:12 PM
Here are the latest pics. I can see the light at the end of the tunnel.
- 37,345
03-27-2010 03:40 PMLooking good......
03-27-2010 05:15 PM
04-08-2010 08:46 PM
I have a couple of pics of the vents, I have been waiting on supplies from US. Should be able to work on them this weekend.
- 4,346
