Over the years a lot of people I have talked with have speculated what would happen if you blow up a Merc # 6 Drive in a Cat at speed.
Well look no further... a week before the Miami boatshow "one a them thar #6's done blowed up on me" a mile offshore of Miami heading south at about 105 MPH.
A lot of people wonder what happens when you blow up a drive in a Catamaran at speed... Essentially, nothing you turn the throttle down, put it in neutral stay on plane and go back to port at 50 MPH instead of 110... Also bring water to keep hydrated! Mind you I have heard the other "well what happens if it seizes"... my guess is with the forces involved nothing will seize the shaft would break and you would lose your prop the boat has so much kinetic energy going forward that not much will make it veer from course unless a rogue wave or Jason Priessly (whatever the f his name is) hits it!
Here is the video, I have it on my website in better definition ( http://www.limestonedev.com/mti/vide...Drive_Done.mov ) but once it is up on youtube properly just hit the highest definition on bottom right and keep an eye on the RPM of the port engine. Also bring plenty of water those cockpit boats get hot!
You might want to turn the sound down a bit!!!!
Double click the "YouTube" Icon in the lower corner for the better view.
Results 1 to 17 of 17
03-07-2010 09:44 PM
03-08-2010 08:36 AM
"That man could break an anvil while playing with it in a sandbox."
Wow. Haven't seen many of those....
03-08-2010 09:22 AM
Well at least you kept your cool and got home safe, I would have been cussing up a storm!
03-08-2010 12:09 PM
[QUOTE=glh;453724]I've tried that a bunch of times and it never fixed the problem so now I attack those issues a different way!!!
Yeah, with your wallet! Love the boat, bring that thing up to Boyne Thunder this summer and run the big water with us! You won't be alone there are other cats, apaches, nortechs there as well.
03-08-2010 07:28 PM
GL, are you driving that thing by yourself? Man, I hope you at least had some help at the dock/ramp!
- 58
03-09-2010 11:22 AMGL, does that boat have any type of AC?
03-09-2010 11:28 AM
No cruising at 100-105 there is plenty of air coming in from two NACA duct on the deck assisted with fans if you need it. Usually at 100 you can turn the fans off and your all set whatever the outside temperature is.
You see the intake under the "O" and the "e" in front of the cockpit here, comes out at your feet in the cockpit;
- Jun 2009
- 1,514
03-09-2010 12:52 PM
I lost a drive at 150 once. Made a racket like the boat was coming apart, but all it did was slow down.
03-10-2010 12:11 AM
And I thought fixing Bravo's was expensive! Please don't tell me a 6 is cheaper to fix than a Bravo.
