Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 44
    Stringer Replacement Harris - materials, process, options........
    Registered HiZ's Avatar
    Oshkosh - Wisconsin
    Ok,
    My friend has a Harris Float boat, deck style with a 5.7 and Alpha set up
    We have removed the power and both stringers are gone. (like a sponge)
    I have found the spot of water intrusion, drilled drain holes (non-sealed)
    So, we are going to tear out and replace them. Bulkhead is ok, Transom ok.
    What products should we use and what process.
    I know quite a bit about glass and lamination.
    But can we laminate on the inside only
    Or do we need to secure from the outside also?
    Just some of your expert thoughts on this........
    Thank you
    This should be a good thread.
    Got some pics?
    Oshkosh - Wisconsin
    Working on it..................
    I will have some shortly
    Registered jeffswav's Avatar
    Oct 2009
    Millstadt IL
    That should not be very difficult. I just rebuilt the entire transom and beefed up the stringers. There are plenty of guys on here that can give expert advise. You can use marine ply for the stringers, 1708 biax glass, you have a few different choices for resin, I used viynal ester.
    Homeless in West Mich
    Quote Originally Posted by HiZ View Post
    Ok,
    Thank you
    EPOXY , EPOXY , EPOXY http://www.uscomposites.com/specialty.html I know this stuff can sometimes cost a bundle and like i stated in a different thread these guys have great prices and sometimes are hard to beat but then again these guys offer great pricing also www.michiganfiberglass.co but you must call for pricing
    Oct 2009
    Millstadt IL
    Polyester resins have a strong odor that stay around. I would not use it on any type of attached garage.
    Oshkosh - Wisconsin
    Ok so engine is coming out and the boat is going to be a start of ripping out the old stuff!
    Laminations of the new stringers to start with marine ply.
    Are there other options?
    How do you work the angle of the hull to the new stringers
    How do you fasten stringers to the hull
    Layers of mat then cover with cloth?
    thoughts ideas
    Main question:
    What do I clean the bilge with?
    Attached Thumbnails Attached Thumbnails 0414001812.jpg   0414002013.jpg   0414002014.jpg
    Oshkosh - Wisconsin
    Prepping the bilge glass?
    Grease and oil, what do I use?
    Serious is the BOMB!
    Looking at the motormount sunk into the stringer, you sure thats not a wellcraft??
    As for cleaning it, your getting ready to rip it apart, coat the thing with a couple cans of engine degreaser then hit it with a pressure washer. Before you even start back there, cover the deck from the engine compartment foreward with plastic and tape it down good or your going to get ground fiberglass in the cracks of the seats etc.
    Got some pics?
    After you degrease could you post more pics of that area and the cockpit and have you determined just how much of your stringer system you might have to replace at this point and with that in mind is there the possibility of you having to cut the liner out to repair everything that is rotted because sometimes these type of jobs can very well be like opening a can of worms ,if you know what i mean .
    Oshkosh - Wisconsin
    I will do that!
    Oshkosh - Wisconsin
    So, looks like there is some Gunk growing from the rotten wet stringer on the stbd side! WOW>
    I also seem to have found the issue, Nonsealed stringer drains that are flush cut, 5/8" hole drilled in the front of the stringer, No sealant on the engine mounts, and A Damn Diet Pepsi in the Bilge
    Attached Thumbnails Attached Thumbnails 0428001631.jpg   0428001632.jpg   0428001632a.jpg
    Oshkosh - Wisconsin
    So, this sucker is nice! it's a 95 and completely ROTTEN!
    Also, that is power steering fluid
    thus presenting 2 questions:
    1)how do you remove w/o draining
    2)how do you bleed and fill
    3)There are only 2 questions
    Attached Thumbnails Attached Thumbnails 0428001633a.jpg   0428001633b.jpg   0428001633c.jpg
    Oshkosh - Wisconsin
    So what do you think
    Attached Thumbnails Attached Thumbnails 0428001634b.jpg   0428001634c.jpg   0428001634d.jpg
    Oshkosh - Wisconsin
    Can anyone tell that it is maintained well by the clean fresh hull!?!
    I like GREZ OFF its my favorite degreaser. Acetone will work well to. Plug the power steering lines and tie wrap up out of the way.
    Oshkosh - Wisconsin
    Yes sir, 5 cans just picked up at O'riley Auto for $1.99 can! WHEW
    So, this is going to get messy!
    HANG ON>...
    After you clean it. Measure and draw what you have before you start removing material. Take a good look at the transom too. Hopefully it is not rotten too.
    Getting messy is an understatement.
    Oshkosh - Wisconsin
    Ok, got that.
    So, what's the deal with fabricating the new stringers?
    How, per say is the best way.
    Plywood lamination. put in with the seams perpendicular to the hull?
    Stacked solid wood?
    Hardwood laminations.
    What's the best way, technique
