Did you find this article?
http://www.brakeandfrontend.com/Arti...t_systems.aspx
Not sure if it will help, but it seems chock full of info.
Low miles, cold weather, irregular use...probably leaky seal allowing accumulator to bleed out.
Thread: 2006 LLY puddle question
Results 21 to 24 of 24
- KPMP
- 509
03-09-2010 12:04 PM
03-09-2010 07:35 PM
[QUOTE=fund razor;454268]I checked out the res, it was down slightly. (It leaked again.)
So, does the sticking valve in the pump force the ps fluid out the cap of the res?
QUOTE]
That is what happened with mine. Mine happened in October when I was in Key West. Came home and not only did I have a river of fluid on my floor to the floor drain, but it stuck with power too it for long enough, it killed both batteries!! Truck had to be put on a flatbed and taken to the dealer...I was a bit pissed!!!! lol Basically, the pump keeps the system pressurized and by not applying the brakes or steering pressure keeps building...
03-13-2010 11:28 AM
I watched it, and found some more ps fluid on the ground. But, the cap and the area below and around the cap are all dry. I wonder if I have a different breach in the ps system? I also left it sit all week without starting it, and I had lost no volts.
