Thread: Technical Info and Hull Designs
Results 21 to 40 of 45
03-06-2010 11:18 AM
Jason did you do these mod's one at a time or not.
Which one helped the most with the rolling over below 40mph.
Question my k planes are 18" long are they the 280's?
Here a few shots I had of the boat it looks like the latest bottom with exception to not having the bottom not filled in under the center drive or is there even more?
And if one was to fill that in what would be the first thing I would notice?
- 37,372
- 37,372
03-06-2010 03:20 PM
Hey John, the mods were done 1 at a time. Your boat would be the 2nd generation hull with the smaller steps, and the chines are not dropped.
The pics below shows what you would do to drop the chines.
Dropping the chines is the biggest thing for stability below 40. Essentially by dropping the chines, you are giving the back section of the boat less deadrise which helps stability. Also, you are giving it more transom lift, which helps the boat run at a little bit better angle of attack, and it might give you a few more mph up top as well as help you get out of the hole a bit better.
I don't know the exact specs on the 280s vs 380's..... In the pics it looks like you have 280's, but I didn't think they were 18" long. If you could get a better top pic view of the tabs, I or somebody else would be able to tell you.
- 37,372
- Jan 2010
- 41
03-08-2010 11:29 AMJohn P., the 380's helped my boat a lot. Make sure they clear your props when trimmed up and turning the drives.
03-08-2010 11:23 PM
I bet the 380's will make a huge difference. If not, just run it WFO, John! Ha, keep us posted, I'll be curious to hear the results.
04-07-2010 11:58 PM
FYI on mercury racing motors
04-08-2010 12:00 AM
Haha, hillarious dude.
Also, we aren't putting the motors back in the boat until the new coolers are done. We want to run them on the dyno.
06-02-2010 08:08 AM
Just a update the 380 K planes are a must, the boat handled 100% better.
