Results 1 to 5 of 5
    Livorsi tach....
    Feb 2009
    Bettendorf, Iowa
    I just took advantage of the sale at cpperformance for the platnum gauge set. I got the tach from livorsi and it has a sticker on the side indicating switch placment between 4 6 and 8 cylinder engines. Where is this switch? Is it just plug and play or is does this not apply to my application? Just wondering if i need to take it apart and set these switches to the appropriate position... If there is even switches contained in the unit.
    Charter Member Griff's Avatar
    Omaha NE
    If you don't see the switch on the back of the tach, then its probably just preset for 8 cyl.
    Need more info about the tach but here are all the tech documents.
    Model #?
    http://www.livorsi.com/tools.htm#t
    Tallahassee, FL
    I think when I installed mine it was behind a rubber plug in the back. pull the plug out and it exposes the circuit board with the dip switch on it. I wouldn't install without checking it first.
    Feb 2009
    Bettendorf, Iowa
    Thank you. I spend an ok ammount of money on this stuff and i did not want to go ripping it apart if i was not sure what i needed to do. Thanks for the help guys.
