Results 1 to 4 of 4
    Prop differences
    Registered BDiggity's Avatar
    Olathe, KS
    Found some 23p 3b cleavers for TRS drives on the other site. Whats the pros & cons between a cleaver & a regular type prop?
    Smile
    Cleavers are suited best for surface piercing set ups. Cleavers do not offer wonderful bow lifting ability.
    If you application can run with cleavers, they will most likely be the faster top end propellers.
    The TRS cleavers are through hub exhaust propellers. These props were old school but very fast on the right application. They are still highly desirable in the right group. I put this in cause I love and am having Brock tonight?!?!?!?!?!!?
    B
    920-295-4435 www.bblades.com
    Huntington Beach, CA
    Out of curiousity (and since I'm entering the black magic world of outboard props) could someone give a rundown on the difference between choppers, cleavers, etc.?
    Both run well on the surface. Both are weight sensitive. Choppers carry the bow well, cleavers don't
    Cleavers are faster in the right application.
    Brett
