Page 3 of 3 FirstFirst 1 2 3
Results 41 to 57 of 57
    Speaking of TRS.... Anyone recall the part number for the spline tool which allows you to put a wrench on the vertical shaft when tightening the pinion nut???
    The Vertical shaft just so happens to be the same size, spline count and diameter as a BMax vertical shaft.....
    91-63620a1 is the Bearing nut wrench and drive shaft socket.
    Thanks Jimmy!
    Damn, they want $110 for that silly thing.... Looks like I'll just take a spare coupler and weld a nut on top of it...
    So get this.. I have a special tools manual from 1998 timeframe... Prices sure have skyrocketed in the last 10 years!
    you can weld the nut like you said, But if I remember they only come together not seprate and you will need the the bearing nut whench to set pre load. Be kind of hard to thighten the double nut set up with a screw driver or chisle while holding the shaft with a couple. But you never know.
    Registered LAKE EFFECT's Avatar
    West end of Lake Erie(K.I or bust)
    Quote Originally Posted by gripit View Post
    Great thread. I was looking for a TRS manual but the link doesn't seem to work any longer. Does anybody have a link or a PDF?
    Thanks
    Full Force has my TRS manual, he should chime in. All you need is the pub # on the service and parts manuals and you should be able to go to Mercury and order some copies. Thats how I got the TRS and Bravo manuals.
    LE
    There is a link to Bams site on last page #40. The manual is listed at $14 or so
    Cleveland/Marblehead, Ohio
    Quote Originally Posted by LAKE EFFECT View Post
    LE
    I will get those numbers up later, I am late for work!
    35 Cigarette Mistress
    Quote Originally Posted by Holy Smokes View Post
    Not really a manual per say, but a complete parts breakdown is always available on Bam's website. Great source of info there.
    http://www.mercruiserparts.com/selec...?doc_nbr=76022
    EDIT>>>
    I just noticed they DO show a manual available for purchase.
    http://www.mercruiserparts.com/Show_...%2FACCESSORIES
    from page 2
    Quote Originally Posted by Clustergear View Post
    Thanks.
    For purposes of my use (BMax/Bravo), I wouldn't need the bearing nut wrench, only the spline tool. The BMax veritical shaft is larger than a bravo style vertical shaft but is the same size/spline as the TRS.
    Mis understood though you were doing a TRS. So I guess you are taking a B-max lower apart. I have never done one so don't know anything about them. That say, for the hell of it if you got 1 1/4 prop shafts on your lowers the prop hubs may fit over vert shaft. If so you may be able to make tool with them. Just an idea
    Forget above post, I just got home from work and checked The TRS spline tool doesn't fit over 1 1/4 prop shaft but it fits perfectly over any Merc input shaft same spline as TRS vertical pinion shaft. If you don't extra TRS coupler you may be able to make a wrench from center of an old engine coupler spline
    Thanks, I'll check that out!
    The Bmax lower is exactly the same as an XR but the vertical shaft is about 2" shorter and the spline is larger and doesn't neck down like the XR does. The BMax lowers are easy, all the tollerances and proceedures are exactly the same as an XR. Also, the lower gears and bearings are the same as a bravo but the gears treated/coated and have a little beefier shafts.
    Frank
    Can I get a copy of that manual I too have a twisted prop shaft
    Quote Originally Posted by BDiggity View Post
    i'll take one. i think one of my drives is taking on water & was going to try & go thru them in the spring.
    Can I get a copy of the trs drive manual.
    Registered Holy Smokes's Avatar
    OP, KS
    Hey guys. I have the complete hard copy of the TRS service manual. No longer needed. Make offer.
