Results 61 to 80 of 1668
01-30-2010 04:34 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
- 37,354
01-30-2010 04:49 PM
We know that Pantera got the molds, what happened to the rest of the tooling? The plugs and such.
Also, you say they have done the bottom themselves does that meen they got the straight bottom mold and now have an insert for the steps and that what you did with the strakes is no longer there? From what I remember you had the strakes running through(over) the steps.
01-30-2010 05:02 PM
The deck Plug was done with The bluefoam was Dow Styrofoam blocks that were piled on a Plywood faced Steel reinforced Pallet, you can then use urethane foam to for glue like a mortor between the lifts then after machining to say deck 1 it was coated with Epoxy a coupling agent and ATC Putty was sprayed on then machined to final dimension deck 2 or whatever.. The Hull Plug was Done differently
01-30-2010 05:04 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
01-30-2010 05:09 PM
Look just because something is CNCed does not make it fool proof,Here you see a batton wrapped around the deck ridge to "sweeten" up the edge and curve.and again a custom file small one made from a piece of 6061T-6 Aluminum.
01-30-2010 05:14 PM"Keep the bottle on the bar Ira, I won't be long".
01-30-2010 05:23 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
01-30-2010 05:50 PM
Very nice. Thanks Steve!
- 2,001
01-30-2010 06:10 PMIncredible insight on what is bound to be an incredible boat, thanks for spending the time Steve, we do truly love this sh%t
01-30-2010 07:05 PM
Steve , only a few of us really understand , how much time is involved in a plug , from the mack up to all the long hours of filling , then sanding with a long board and then repeating that whole process over and over till everything is just right Dammmmm i get tired just thinking about long boarding for 8 hours a day and week's on end .
01-30-2010 07:12 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
01-30-2010 07:16 PM
Is that Duratec flexable? Would it work in the auto body world?
01-30-2010 07:17 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
01-30-2010 07:19 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
01-30-2010 07:22 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
