Thread: turbine boat question??
Results 21 to 40 of 107
01-26-2010 06:26 PM
01-26-2010 06:29 PM
Ask Knot Rght he has the 46 turbne skater around here very very smart in ths aspect he did his homework.
-Mike
01-26-2010 06:29 PM
The starter is a generator as this is a DC motor. Simply put, the input shaft to the DC motor is splined and fits into a right angle gear box which in turn powers a gear (via a shaft) that is attached to the Compressor.
Being that on these engines (T53's and T55's) this is a purely "live" connection when the compressor is spinning it in turn rotates the DC motor.
When one closes the shunt field on a DC motor it becomes a DC generator.
01-26-2010 06:34 PM
Nope not Hellfire, Hellfire's cockpit is a lot smaller and its exhaust is at the transom. But still sweet!
http://www.youtube.com/watch?v=j4Tr0syhIIo
01-26-2010 07:02 PM
Thanks Rik.
01-26-2010 07:25 PM
The noise you here is the Power turbine wheel comming to a hault.
This is done by a caliper squeezing a rotor stopping it.
Then you engage the crash box and select forward neutral or reverse.
Here is a video worth 1000 words
http://www.youtube.com/watch?v=2HpbYDFGrkA
01-26-2010 07:37 PM
The 53 and the 55,s are Gas Turbine engines.
This means there is a gas producer n1. and a power turbine n2
These two systems are completely independent of each other.
N1 is the gas producer which means it produces Hot gas (Combustion)
that is directed and focused onto the Turbine Wheel (N2).
At low Rpm the Force is not significant enough so that the design
allows the N2 to be stopped without issue.
Picture a compressor airgun. EX. like a blow off nozzle that a garage uses
to blow debris off something.
If you put a free spinning Wheel in a vice. EX. Like a Computer fan.
If you apply the airgun to the fan the force of the air against the blades
will cause it to move. It will Move pretty fast also.
Imagine this computer fan coupled to a shaft and attached to a prop.
This is a basic analogy.
01-26-2010 08:03 PM
In a helicopter n1 is the throttle. and n2 is the rotor speed.
These are both adjustable by the pilot.
Throttle and Collective pitch.
The rotor increases and decrease pitch in turn starts to pull the rotor
speed down . There is a droop compensator which keeps the rotor
speed up in the event the pilot has a heavy load Ex, lifting logs etc.
In a boat the n1 is the throttle and n2 is locked down at a given setting.
In one of my trial runs we could not get the boat over 100.
The n2 was locked down to low. simply backing out the stop screw is
all it takes.
Now you could certainly run a throttle on n2. this would give you
two throttles on each turbine.
In caution one needs to remember the n2 control is the actual governor
of the rpm. the maximum rpm of this is roughly 23,000.
By pulling back on this lever as in leaving the water would never
slow it down quickly enough as not to cause a overspeed.
Hope this helps
01-26-2010 08:06 PM
Here is the helicopters these were engineered for
t53 huey
t53 703 cobra
t55 chinook
Anyone wanna guess why its called t53?????
01-26-2010 08:31 PM
53, 5 Stage compressor, 3 stage turbine
2005 Formula 330ss
01-26-2010 08:31 PM
01-26-2010 08:36 PM
good answers..............
It was engineered in 1953
- Jan 2009
- 56
01-26-2010 08:43 PM
anticipating the water and pulling back faster.
Most turbine installations have the n2 locked down and throttle the n1.
In any case it will throw torque at the drives like ya read about!
- St. Petersburg, FL
- 3,965
01-26-2010 08:59 PM
