Results 1 to 15 of 15
    Steering Leak, External Hydraulic Ram
    registered
    St. Petersburg, FL
    Hey fellas,
    I discovered I have an ever-so-slight leak coming from my external hydraulic ram. I see a couple drops on the ground where my boat is stored, and a small drop of red fluid dangling from where the piston meets the cylinder.
    See photo for location.
    I discovered this last night. The boat's been sitting for about 2 weeks, and prior to last night's finding I had no indication of any leaking. This is new.
    I wiped everything up at the site of the leak and dried it completely. I fired the steering motor and actuated the steering full left to full right about 50 times. I saw no fluid or leaking. But after it sat all night, I see a drop dangling from the seal there again. Again, it's only like a drop or two on the ground.
    The reservoir is full, so there's no major loss of fluid, just a few drops.
    Also, the steering behaves perfectly normally and is tight.
    (1)Is this something you guy would consider a simple nuisance leak or something more serious to be concerned with?
    (2)What's the fluid? I assume it's ATF by look and feel.
    Thanks in advance.
    ATF is what's in mine, You can run it but get it fixed cause if oil can get out salt water can get in.
    Run until it sounds expensive
    Where the summer never ends
    Salt water will not get it, the only reason oil gets out on a small leak like that is because there is over 1000 PSI on it !!!!!!!
    Its an o-ring under the threaded part of the flange. EASY FIX, o-ring u can buy at NAPA !!!! or any hydraulic shop !!!!
    registered
    St. Petersburg, FL
    Thanks guys. I appreciate it.
    Not when the engine is off and you're sitting at the bar having cocktails!
    If it were me I'd probably run it for the weekend and keep an eye on the levels but get new seals and scrapers. You can probably do it yourself!
    Good luck, enjoy the weather!
    registered
    St. Petersburg, FL
    Thanks again. Had a great ride. Alls normal. Were at hula bay. Beautiful out here. Ill get it taken care of tomorrow.
    They don't typically "just go bad". You may have a ding on the shaft somewhere that's cut the wiper. That's alot more than an o-ring in there. Those are double-acting cylinders and they'll have either T-seals or polypaks on the piston and the cap. Will have a wiper in the cap too. You have to be careful not to nick the seal on reassembly- they probabaly have female threads in the cap and if the bore isn't chamfered well on the tube, you can scuff the seal- and it's done. Thake a look at the bores- they need to be free of any longitudinal marks. You can mildly hone them with a brake cylinder hone on a drill but extension. Slow speed, correct cutting oil and fine stones. Then a very thorough cleaning.
    I cleaned mine with a scotch brite and it worked perfect. The o-ring right behind the cap was gone on mine ,,,same slow leak !!!
    U be amazed how simple a trim cylinder is , once u open it up .LOL
    Is it Latham? Give them a call.
    Yes...Give'um a call if Latham. Great company to deal with.
    No doubt, I thought the same thing!!!
    These are easy by comparison having rebuilt a 10 ft (closed) hydraulic ram for the forklift at the marina!
    registered
    St. Petersburg, FL
    Many thanks guys.
    Chris, the piston is smooth and uniform. I looked it over very carefully at full extension - No scratches, scars, nicks or anything evident.
    registered
    St. Petersburg, FL
    No. It's a WPM system.
    Not the piston, the rod. Thats where the nicks would be.
    registered
    St. Petersburg, FL
    Sorry, that's what I meant - the external visible polished rod at full extension.
