Results 1 to 14 of 14
    Bottom Paint on a 43' Wellcraft Cruiser
    Registered JETJOCK's Avatar
    Anyone have a ballpark on what it costs to paint the bottom on a 43' boat?
    Specifically a Wellcraft Portofino.
    Registered DollaBill's Avatar
    $20-50/ft. depending on region, paint and how much prep
    Charter Member 95south's Avatar
    new jersey / south beach
    use ablative paint. you will need some where around 2 to 3 gal if it was never done before.
    I use 2 gal on my 41 ft carver
    it is messy but you can do it your self.
    Mechanicsville VA
    That is a 88-91 model so I'm thinking it's been painted before. Been years since I had cruisers but I used to paint them myself. It will use 2 gallons and if you put 2 heavy coats on (recommended) you could be into a 3rd gallon. Have it hauled and blocked to do yourself. It's not hard, a bit messy, and that's where all the $$$ is for the job. I always used the best paints I could since the labor effort was the same regardless....spent about $150/gal 10 years ago.
    Are you talking about putting on bottom paint again or getting rid of the bottom paint and going with gel or a eurathane?
    Quote Originally Posted by Audiofn View Post
    Painting again, the boat is a 1989 Model Wellcraft Portofino
    depending on your budget use an Interlux product. Micron 66 is the best, but its also 250/gal.
    Burrito Springs Florida
    Have to agree on the Micron 66 and go for 3 coats minuim 4 on the hi wear areas.That will buy you more time between halouts.
    Its been a few years since I had a cruiser, but I specifically remember that there are bottom paints better than others depending on what type of water the boat was going to be sitting in ( ie brackish water ) so check into that before blindly putting on a brand or type.
    Mechanicsville VA
    and use Ablative paints that wear off over time!!!! also, I was told (not long before I sold my last cruiser) to paint the bottom with one coat of color, then several coats of black. Once the coats of black wear to the last coat of color it's much easier to see that it is time to re-paint.
    Quote Originally Posted by JETJOCK View Post
    let me know if you need more info. I'm actually an expert on this stuff. Hard to believe but true LOL
    painting the bottem is a picnic compared to sanding and prepping the bottem.unless you bead blast it. It took me about 18 hours split between 3 days to sand and prep my 38 footer...... couple hours to paint. NEVER AGAIN!!!
    Registered Hammer01's Avatar
    May 2009
    Chicago Northside
    Quote Originally Posted by tcuda499 View Post
    I was waiting for someone to come up with this response. We did a 34 Sea Ray that had a freshwater bottom paint already and the sanding and prep sucks but worth it for $2k or so. The bead blasting would probaby help but still had to sand the edges near the water line, tape it so it would look superb, and we unfortunately did it when it was about 100 degrees on a Saturday hangover morning!!!!
    Registered Rush's Avatar
    Chesapeake Bay
    Quote: we unfortunately did it when it was about 100 degrees on a Saturday hangover morning!!!!
    Isn't that when your suppose to do it.
