Results 41 to 60 of 75
    Charter Member NASCAT's Avatar
    Charlotte, NC
    Checked w/ Randy those were just stage props (no pun intended) for the photo opportunity. So you see sometimes we must refrain from being quick to judge & give the benefit of the doubt. Mystery solved & case closed! I think my work is done here!
    Charlotte, NC
    Quote Originally Posted by stainless View Post
    32b (it's a 2007 ,they stopped making the original 32 a while ago- 2001 I believe??), still playing with props, and have to recalibrate the gps after switching to a battery free antennae, so not 100% sure on top speed.(You can watch GLH's video of the hudson run to get some ideas of the speeds we were running) The 6 drives on boxes really keep the boat hooked up and let you leverage the boat to do things with it you cant on a bravo boat. The nice surprise is the awesome gas mileage i've been getting out of the Ilmors, very surprised and much better than i anticipated.(Would estimate about 2 mpg crusing at 100) There are only 2 back seats , so the wind down the middle is not an issue as there's no middle rear passenger.( I can run wide open with virtually no wind behind the qtr canopy) Overall, Pete did a real nice job, as usual!
    Steve,
    My GPS Speedo antenna crapped out too & I went thru the whole battery replacement w/o any success so I wired mine directly into my Garmin GPS & it works perfect as long as I have the Garmin uncovered & on. No calibration necessary. It's running both my front & rear speedo plus the Garmin digital display.
    If I had my way I'd lose most of my gauges for a few Data Tachs. I have 4 Tachs & 2 speedos in my helm. Data tachs would clean the dash up nicely. I'm not really a smartcraft display kinda guy although I know many of the newer high end boats are incorporating those style.
    Attached Thumbnails Attached Thumbnails Skater 30 cockpit front.jpg   730-DataTach_PropSlip_A.jpg
    Registered Bradz's Avatar
    Illinois
    I am wondering why the boat only runs 101 with 710's? The slip ratio of 14% is high and the speed seems quite low. I would guess closer to 135 mph. Maybe I did not read the thread correctly?
    Charlotte, NC
    Brad,
    Thats a photo I took off of Livorsi's site (LMAO) but good eye. I don't actually have a Data Tach but was saying I wish I did in order to consolidate the bazillion gauges.
    Actually my boat ran 137 w/ the original owner & different props, my personal best 135 so you are spot on.
    Quote Originally Posted by NASCAT View Post
    Steve,
    Only problem is I've got a north star gps, and it only reads to 99.9 mph
    Charlotte, NC
    Obviously I needed to give you more credit but less to the original owner or whoever spec'd that bad boy out for a Cat Are there any Cat's that go less than 100?
    Charlotte, NC
    Steve,
    Did you get my PM about your current props. I know you gave me the sizes etc but do you know the rake & what gear ratio your drives are? I'm using your setup as a starting point for mine & they want to know what ratio. The DCB's & Eliminator w/ Indy drives all have a 1.39 ratio which is close to my Bravo 1.34
    Illinois
    Brad,
    Great! That makes more sense than the 101 mph.
    Charlotte, NC
    5240rpm is about 1000 shy for the V-10's too!
    Steve,
    18deg rake 1.5 gear ratio
    We saw 6500 last yr
    I think Allen liked north star due to his aviation background, prob didn't realize that this unit stopped at 99.9 other than that, it's a nice gps
    Charlotte, NC
    Thank you, thank you & agree!
    Sponsor / Charter Member ILMORdude's Avatar
    We saw 6500 last yr
    ILMOR High Performance Marine
    Charlotte, NC
    Steve by the look on IlmorDudes face I think you just voided your warranty!
    That puppy was voided a while ago! That's where the rev limiters kick in. They're just starting to sing at that rpm!
    fun day...Old Saybrook to Bristol, RI, isn't that where Outerlimit's are built?
    down to Newport, buzzed back to OS...ocean swells..little chop...big chop..
    boy...those props on a SSM VI outdrive just stay "hooked up"!!!
    Thanks for the blast Steve...
    Attached Thumbnails Attached Thumbnails downsize 2.jpg   downsize 1.jpg   downsize.jpg
    Had a great day guys!
    Mint boat!!!
    Quote Originally Posted by Ktron View Post
    Mint boat!!!
    Thanks Ktron!
