Results 1 to 20 of 93
    Throttle Up CNC Propellers
    St. Petersburg
    I have some inventory propellers, that I am going to sell. They are all 5B Bravo Drive CNC Machined Propellers. In the spirit of the swap shop and the holidays I am selling them at $500.00 each. Email me if you interested and also include the size you are looking for.
    Happy Holidays!
    Julie
    Throttle Up Propellers
    SAI
    727-531-2255
    Last edited by ThrottleUp Props; 12-16-2009 at 10:53 PM. Reason: Needed Clarify drive type
    GO FAST or GO HOME!
    can we get the gold ones for that price?
    St. Petersburg
    Oh, the private collection!!!! Safe and Sound of course!
    Julie
    GO FAST or GO HOME!
    what do they look like?
    are they similar to the maximus?
    I would be interested in a pair of L & R 28 pitch.
    St. Petersburg
    They are semi-cleavers. The Maximus is a High Rake Round Ear prop...the only thing similar is the Hydro P5-X.
    Julie
    GO FAST or GO HOME!
    Charter Member Griff's Avatar
    Omaha NE
    Quote Originally Posted by ThrottleUp Props View Post
    Julie
    Don't you mean the regular P5........not the P5-X which is similar to the Maximus???
    St. Petersburg
    Correct... I was stating the Maximus IS similar to the P5-X.
    The P-5 is an out of the box semi-cleaver, non-CNC propeller. Sorry if that was confussing.
    Julie
    GO FAST or GO HOME!
    Tallahassee, FL
    Do you have them in smaller sizes, like 24 or 25 pitch? I'm running 26 bravo 1's now and I imagine these would need to be smaller in pitch? Are the CNC'ed props basically labbed out of the box because of the precision of CNC?
    St. Petersburg
    I am sorry the smallest pitch made is a 28P in Stern Drive props. We do manuacture our outboard overhub props as small as 25P. Our SM props as small as 28-29P in 5B and 6B configurations.
    If you are running high rake props there are no CNC versions available to date.
    You are also correct in that CNC propellers are machine finished props, tight tolerances vs lab finished props from stock castings.
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    I also have some SM props:
    5B Speed Master Props:
    16.25 x 36P 5B 18 deg 650 HP RH & LH
    16.25 x 40P 5B 16 deg 650 HP RH & LH
    16.25 x 39P 5B 18 deg 650 HP RH & LH
    16.50 x 35P 5B 18 deg 850 HP RH & LH
    I will let these go, at a significantly reduced cost as well!
    Julie
    GO FAST or GO HOME!
    Tallahassee, FL
    Julie
    Well, with that said... I'm running a 28 Donzi ZX (twin step). I read about the P5's and they sound appropriate for a step bottom boat. In your opinion, do you think I could swing a 28 pitch considering it is CNC'ed Vs my stock Bravo 1's?
    St. Petersburg
    What engine package?
    If you running the 26P Bravo I props (which are really 25P) at the appropriate RPM then no the 28P props would run about 750 RPM less, s they would be 3 inches taller in pitch and the additional blade. I am afraid they would be to tall for you.
    Julie
    GO FAST or GO HOME!
    I am running 32 maximus @ 3650 RPM and want to get to 3800 whit dieselpower (320 hp each )also have a set 34 bravo's but no test data yet because of the winter .
    What do you think/advise
    thx
    St. Petersburg
    Bor... tell me a little about the hull please. Also can you tell the diameter of the 32P Maximus props?
    Julie
    GO FAST or GO HOME!
    Please excuse me if I missed it but did you list the pitch of the 5B Bravo props in Post # 1?
    Cause somebody has to!
    St. Petersburg
    Yes sir....I can do that!
    5B RH & LH : 15.25 x 27P, 28P, 30P, 31P, 32P and 33P
    5B RH & LH : 15.0 x 30P
    5B RH & LH : 15.50 x 32P
    5B RH 15.25 x 29P
    5B RH 15.50 x 33P
    5B RH 15.25 x 30P
    Thanks for asking!
    Julie
    GO FAST or GO HOME!
    Did you tell me to subtract 2" of pitch when going from 4B to 5B?
    15.25" diameter will fit an XR -2" sportmaster correct?
    Lake Nasty
    You're an individual, private seller, right Julie? I was doing a little moderating in here (kind of lazy really) and wondered.
    Thanks.
    Lake Nasty
    Ok, so I am done wondering and since I have such little authority... (this is it.... swap) I have decided by proclimation that since I just called you "Julie" you are obviously an individual private seller.
    So Merry Christmas and make sure to advertise on SeriousOffshore.com when you plan your 2010 marketing campaign.
    St. Petersburg
    Yes Sir, I THANK YOU!!!!! Thats why the Bravo Props are $500.00, to comply with the Swap rules!
    They are my private collection, which is why I can sell them for $500.00 each!
    Julie
    GO FAST or GO HOME!
