Page 5 of 5 FirstFirst 1 2 3 4 5
Results 81 to 93 of 93
    St. Petersburg
    Sorry, no Bravo I props. Try Cobra Power, in Miami.... he may have some.
    Julie
    GO FAST or GO HOME!
    Julie,
    What is let in the 5 blades.
    St. Petersburg
    I am assuming you are asking about Stern Drive props? I will check and please correct me if I am wrong on drive type.
    Julie
    GO FAST or GO HOME!
    You are correct.
    St. Petersburg
    Thanks. What diameter and pitch are you looking for?
    Julie
    GO FAST or GO HOME!
    I will have to check, this is for a friend. He did say 27 but not sure on Dia. It is for a 1989 Cigarette Bullet w/Twin Mecury 575sci with Bravo XR drives. The boat came with29 3 blades spinning 4500 at 72 mph.
    St. Petersburg
    The smallest we make in a 5B or 6B is a 28P. I am not sure semi-cleavers are right for him though.
    Julie
    GO FAST or GO HOME!
    Thanks Julie, He talked to Hydromotive and they said a 5 blade 28. Not of which one and the spec's.
    St. Petersburg
    Quote Originally Posted by wildthing View Post
    Lets start with his current equipment and go from there.
    Julie
    GO FAST or GO HOME!
    julie,
    1999 38 scarab avs. 500efis 550 hp running b1 30pitch to 5100rpm at 80mph. X dimension is really high and really slow getting out on plane. would your semi cleavers props work for me? thanks
    St. Petersburg
    tcuda499,
    Your hull really appreciates high rake props, like the Bravo 1 or the Hydromotive P5-X. The semi-cleavers cleavers make it a real bear to plane. I would try to find some P5-X props in all honesty.
    Julie
    GO FAST or GO HOME!
    thanks Julie
    St. Petersburg
    You are more than welcome!!!!!!
    Julie
    GO FAST or GO HOME!
