Results 41 to 60 of 93
    St. Petersburg
    Quote Originally Posted by Steve Miklos View Post
    Julie call me on 27 28 30
    Thanks
    Steve
    Sorry I am running behind today.....I will call you in the morning.
    Julie
    GO FAST or GO HOME!
    Quote Originally Posted by ThrottleUp Props View Post
    Bor... tell me a little about the hull please. Also can you tell the diameter of the 32P Maximus props?
    Julie
    It ,s a 1989 32 hustler straight v- hull whit notched transom , there stock 32 maximus 15 5/8 diameter
    thx ,
    Bor
    St. Petersburg
    Quote Originally Posted by bor View Post
    thx ,
    Bor
    Hey Bor,
    High rake props are really best for your hull....however if you feel you can afford more stern lift, then we can look a your data. Traditionally, Older Conventional Vee Bottom Hulls, appreciate the high rake, as the propellers will help to carry the bow (since you have no steps to assist).
    Julie
    GO FAST or GO HOME!
    Hey Bor,
    Julie
    Hey Julie,
    The numbers are quite good have a slip number of 7 % .
    first thing when the snow is gone here I am going to try the bravo,s and get some more data also gonna get the exact weight of the boat .
    also want to try some 1,36 gear ratio to get the prop speed a little up
    When I have some more data I will contact you again
    thx bor
    St. Petersburg
    Sounds great bor!
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    Thanks
    Steve
    Steve,
    I have sent you a PM!
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    I still have several sets available....now that the holidays are over, lets talk performace!
    Julie
    GO FAST or GO HOME!
    Hey Thanks for the props Julie,
    They are gorgeous. A guy needs a sweet deal once in a while.
    Cause somebody has to!
    Hi Julie,i have a set of your P5x in 32.they are about 750 rpm off the where i want to be.What would you suggest in the P5.Running slightly altered Bravo 32's at the moment @ around 6000.Or am i better going with a set of 30 P5x's?
    Bristol, RI/Wethersfield, CT
    Julie
    Clear out your PM's Julie!
    St. Petersburg
    You are so very welcome!!!! I think your boat is going to run very well with the props.
    Thanks!
    Julie
    GO FAST or GO HOME!
    St. Petersburg
    Quote Originally Posted by fastlane40 View Post
    So are they a little tall for you, I assume? If you are shy on RPM then lets get you in a set of semi-cleavers and light her up!!!!
    If you wish, PM the details to me and I'll get started.
    Julie
    GO FAST or GO HOME!
    Hey Julie,
    I have a DCB F32 with Teague 800's EFI . Imco SC drives.
    Current props are 4 Blade Bravo Stamped 37 Pitch. They are labbed. I purchased the boat used,the props were supposedly done by Merc Racing.
    The boat I am told has done 137 with these props. I have been to 130 with stick left. The boat rolls over fairly well but I am thinking a 5 Blade prob may be better for crusing.
    Thinking about maybe a 34 5 blade. Would any of these props you have be suitable.
    Thanks,
    Jeff
    St. Petersburg
    Yes I think I may have something for you. Why dont you PM me your performance data so I can take a look. I am curious because it is very rare when someone tells you they are running a 37P Bravo! Almost unheard of actually.
    Julie
    GO FAST or GO HOME!
    Julie
    PM sent
    St. Petersburg
    Thanks look forward to talking with you!
    Julie
    GO FAST or GO HOME!
    31's are sold! Thanks Julie for all your help. Cant wait to try them out....now its really going to be a long next couple of months!
    St. Petersburg
    They are on their way~!
    Julie
    GO FAST or GO HOME!
    Do you have any 5 blade props for #6s? looking for 18x34.
    thanks,
    Ben
    St. Petersburg
    Here is what I have left from my private collection.
    16.25 x 36P 5B 18 deg 650 HP RH & LH
    16.25 x 40P 5B 16 deg 650 HP RH & LH
    16.25 x 39P 5B 18 deg 650 HP RH & LH
    Now we, Throttle Up Propellers/SAI can make you a custom set of propellers as well.
    Julie
    GO FAST or GO HOME!
