Results 21 to 40 of 119
    Georgetown, TX
    Jim - router in the shop if you need it. have a brand new 10" table saw, too
    Boat-less...
    Apr 2009
    o yea ,,, i have a router and a table saw ,,,,,and a DRILL,,!!!!
    Thanks Guys. All in need is some gitterdone
    Homeless in West Mich
    nuthin' pretty about that except your stellar craftmanship of course
    Of course , and wow , i cant believe all the bare wood and Jim have you decided on what core to use ?
    I'd gut out ALL That wood and replace it with some sort of cored panels, 1) it'll give you ample room to work in there. 2) you'll save 100+lbs. 3) It'll be a much better job than they did back in 83...
    Sponsor / Charter Member mbam's Avatar
    Pompano Beach Fl
    Jim for what it's worth last winter I replaced the deck panels in the cockpit of my cruiser. They were plywood and rotted out. I went with divinicell (spell?) type foam that we laminated on a big formica table with biax on both sides. You could not get me to use anything that grew in tree form as a core unless there is a good reason like an engine stringer. Unless there is a compression load like tightening a bolt the strength is in the glass anyhow. I go with FastDonzi. It was probably overkill but we used vinylester.
    Jim , i thought i would post this for $hit's and giggles http://www.coosacomposites.com/nautical.html Jim there is the Blue water and the Nautical series which is more economical as far as price goes .
    My Coosa rigid panels get shipped the 17th.
    1 sheet 1"and 3/4". 3 sheets 1/2. 153 lbs total.
    Jim , you sure are going to be saving some weight considering that 3/4 ply weighs an arm and a leg .
    Finally got a chance to go back at it.
    I did cut and fit the pieces under the v berth. I hope to glass them in tomorrow. Here are the parts cut from the 3/4 inch panel.
    Dam Jim , L@@ks like the space shuttle ..............ground control to Major Tom (Jim)
    The space shuttle has more head room.
    Jim , you have to remember it was only made to HUMP & BUMP .
    Only the fwd piece is glassed. The remaining piece fit.
    Hope to glass them all in tomorrow.
    Jim , l@@kin good .
    Serious is the BOMB!
    looking sweet Jimbo!
    Registered Trim'd Up's Avatar
    STL, on the ILL side
    Ahhh, the memories. Looks good Jim, just glad I'm not doing it again.
    Round 1 today. This is no fun doing it alone. I will be glad to get out of this forward section.
    Its just about time to prep the next section. I will grind out the marglass that I tabbed it in with and mud in the next center section. I think I will mud in the next cross piece now I have I little more room so I can do the entire block at once.
    Georgetown, TX
    couldn't wait for me, huh? You'll have some left for the weekend, won't you?
    Boat-less...
    If you were helping I wouldn't be wetting out on my lap.
