is this a 3 or 4?
Thread: Is this a 3 or 4...thanks
Results 1 to 20 of 35
12-14-2009 08:37 PM
that is a speedy 2 or a 3
Ryan Beckley
12-14-2009 08:53 PM
any distinguishing marks to tell??? I thought it looked a little beefier than a 2....a two is a trs upper correct?
12-14-2009 08:59 PM
I don't know the exact specifics. I know a 4 looks like a 5 with the square rear on the upper. I think you are right that a speedy two is a trs upper.
Ryan Beckley
12-14-2009 09:10 PM
Looks Like a 3. The 2's had different caps where the steering mounts. And the Transom assembly is larger then the TRS or #2
Mark
12-14-2009 10:30 PMSSM 2
That's a TRS gimbal. It has 1/2" studs to mount the outdrve and the small propshaft. Plus the small trim rams.
They're rare, and valuable. But if you break one you'll learn why they're rare and valuable. Power handling was less than the TRS. All of them I ever saw were set so low in X that it wasn't funny. They were a few inches longer than a TRS.
12-14-2009 10:42 PM
upon further inspection (my bad photo) if you take the block off the back the steering attached too, the drive gets small quick....i guess it just looks bigger since it is on a small transomn...thanks for the help
- May 2009
- 54
12-14-2009 10:47 PM#3 not a trs t/a its a small shaft 3
trs t/a is much smaller and shorter... this is one of the 1st 3s # 2 had a very large mid section and vents, almost like an outboard...
12-14-2009 11:29 PM
too me it screems ssm II 2 cents
beer is food
- 2
12-14-2009 11:38 PMIt is an old number three, it was the drive before the 3a. I also have one just like it,i.25 gear ratio and short shaft. John m.
12-15-2009 12:26 AM
You guys.
It IS an early 3. TRS does not have the fill in the rear cover. And the side where the decals are on the upper is smooth. TRS it sticks out.. Also the spacing on the studs is different the TRS.
I am willing to bet anyone who is willing to say different.
12-15-2009 12:32 AM
12-15-2009 12:45 AM
get em Jim !
12-15-2009 01:02 AM
Pretty sure it is a Scarab. I could check.
Parts are limited. Not sure on details. Bearings and seals you will be able to get. Shafts and gears maybe not. I wouldn't think you can break it on a small boat. Just keep lube in it.
I would contact Craig Colabella in St Cloud for more details.
12-15-2009 08:31 AM
Thats a small shaft SSM3, 3A is big shaft
Quite a lot of those oldies around here...Offshore Racing wasn´t designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
