The Merc ITS has somewhat of an extension box on it but only about 7" compared to the 12" of an Imco box...
How much different would the performance be between the two? Which one is better?
Thread: Merc ITS vs Imco standoff box
Results 1 to 15 of 15
- Apr 2009
- 7
12-03-2009 03:53 AM
12-03-2009 07:30 PM
I've always wondered the samething.
Anybody?
- 23
12-03-2009 07:35 PMHave the best of both worlds. ITS and a 12" setback
http://www.everettperformance.com/Ze...ion_Spacer.asp
- Apr 2009
- 7
- 23
12-03-2009 07:45 PMAdd this outdrive to my suggested transom combo and Bammmmmm. See JIMKIDMOTORSPORTS and his 30 Skater.
http://www.xpowerdrive.com/
- Apr 2009
- 7
12-03-2009 08:08 PMYes the Xpower drive is a good looking drive and suposedly pretty bullet proof but there aren't that many out there so if I were getting one, I would wait longer till there are some good on the water public testemonials....
Also, I should have mentioned I am asking these two setups in single engine vee bottoms...
01-13-2011 04:42 PM
hii can this stand box work on 50 ft powerboats with 3x502 magnum engines
- Jan 2011
- 677
01-13-2011 09:02 PMHi, if u have Bravo's ...don't see why not !!??
- Jul 2010
- 24
01-13-2011 10:38 PMwill the IMCO SCX upper go onto the Merc ITS transom assembly??
Ive been kicking around buying an old 30' Corsa that was raced and had TRS's and just thinking what would the best set-up would be before I start thowing money in all directions..
- Jan 2011
- 677
01-14-2011 12:42 PM
no it does not have a trans ,,it works like a sc only all the gears and cluches are 50% larger ,to put the scx on a standard gimble you would need to change the bell only not the gimble ring ,,well worth the upgrade
- Jan 2011
- 677
01-14-2011 01:53 PMThank you for clearing this up. I wasn't sure !
Is that your boat in your picture?
I watched some races and think i seen it before, nice boat.
04-07-2011 07:43 PM
hi there again me what you think about upgrading mercruiser bravo drive 1.50 :1 with :
1.shower for cooling
2.extension box
3.nose cons
usually how many miles can get with those upgrades
on 12 m hull with 2x 502 prochargered ( 2x620 hp)
Thank you in advance ,
Ivan
- 37,340
06-29-2011 05:36 PM
hi guys I changed plan for 10 m with 2x502 p[rochargered to 1 x 502 + pro on 7 m hull , I want to put same things to it what you think
best regards,
Ivan
