Page 2 of 2 FirstFirst 1 2
Results 21 to 39 of 39
    Quote Originally Posted by blackhawk View Post
    Have you tried a standard Mirage? It has less cup than a Plus and you get a couple hundred more rpm. My boat likes the Mirage much better but it slips a lot more in the mid-range. FAST prop though.
    jeff i put a 150drive on my boat runnig a 25mirage not a plus. 5700 5800rpm i was doing 80.4mph gpsi am going to try a 25plus next
    Registered jeffswav's Avatar
    Oct 2009
    Millstadt IL
    My boat likes a lot of cup on the tips. I have twice the cup as a Mirage plus. The slip numbers are a lot higher with the standard Mirage.
    Registered blackhawk's Avatar
    Jun 2009
    Got ya. Every boat is different and my boat loves the Mirage at WFO. It actually slips less than the Mirage Plus(like 7%) but it definitely slips a lot more at cruise.
    BTW, love the Ram-air post!!!
    Oct 2009
    Millstadt IL
    Thanks, by the way it worked. Only about 1 or 2 MPH but that is huge for me.
    I am trying a Hydromotive 4 blade 23p this weekend. I borrowed it from a freind I will let everyone know how it works.
    Jun 2009
    Some people spend a lot of money on motor mods for 1-2 mph!
    If the Hydro isn't an X it will need A LOT of trim to get bow lift. They lift the stern quite a bit and ride flat. Some boats really like them though.
    Oct 2009
    Millstadt IL
    I tried the same prop about 4 years ago. That was with before I raised the x dim and with less HP. Back then it would not lift the bow enough to get any speed, it ran real flat. Well now with the raised x the boat runs flater and faster and I may not need the bow lift of the Mirage. Never know until you try it.
    Jun 2009
    Yep! I NEVER pass up an opportunity to try a prop!
    FYI - The best 4-blade I have tried to date is the Rev4. Just as fast as a Mirage Plus with great bow lift, awesome handling and a strong mid-range bite.
    Jul 2010
    Stony point
    Need help have a 86 scarab panther 30 foot with 2 502 with trs drives....can't figure out what props will stop the engine from over revving?
    Registered Donskihp's Avatar
    Mar 2010
    VA.
    Denny, need more info! What props are you running now? Brand and style, diameter and pitch? What speed are you running and whats your slippage?
    Oct 2009
    Millstadt IL
    Quote Originally Posted by Denny View Post
    Denny, start a thread specific to your problem and we will all give input. Some of the pro's will give a little input also.
    Jul 2010
    Stony point
    86scarab panther with 2 502 with trs drives.. Need props that won't spin???
    Mar 2010
    VA.
    Denny, call Brett at bblades
    Oct 2009
    Millstadt IL
    OK, here are the results of the Hydro 23p. I could only pull it to 5300 RPM @70MPH, I could pull more RPM but it would loose speed. Prop slip was good at only 9%. Overall it felt good, it planed of better than the Mirage, but at least 2MPH slower given the heat. If I did a lot of skiing and tubing and made a lot of turns this prop would work. Probably a better prop for stepped hulls given that a lot of Fountains run these props. I may try a Bravo prop next just have to find the right timing to borrow one.
    Jul 2010
    Stony point
    Can you tell me how to contact Brett?
    Jul 2010
    Stony point
    I have tried Mirage 23 and 25 both three blades.
    I tried bravo 27 4 blades.
    I tried bravo 32 4 blades.
    I am running Mach 1 24 4 blades they seem to be the best.
    I hit 4000 rpm and they spin....
    Mar 2010
    VA.
    Brett @ bblades 920-295-4435
    Mar 2010
    VA.
    bblades also has a test program you might want to inquire about. The test program worked pretty good for me.
    Jul 2010
    Stony point
    Thanks i will try brett
