Results 1 to 13 of 13
    Leverage FSR & Hull Cleaner, Fiberglass Wash & Salt Deposit Remover
    Charter Member MarineClean's Avatar
    Lake Ouacihta, AR.
    It's time to get the cat out of the bag. I've also been working on my FSR(Fiberglass Stain Remover) & Hull Cleaner. As with everything I do the FSR will be non toxic, but remove scum and stains like a charm!
    My Fiberglass Wash & Salt Deposit Remover is formulated for use on your boat both in fresh and salt water applications. Again, non toxic in a low sud formula.
    I will have both of my new products finished and on the market around late January. Pricing will be half of what you guys are currently spending for other formulas!
    Attached Thumbnails Attached Thumbnails S7001164.jpg   S7001166.jpg   S7001170.jpg
    Will it be safe to use on Gavi trailers?
    Cool, Let us know when it is ready for purchase.
    Lake Ouacihta, AR.
    Quote Originally Posted by Audiofn View Post
    Yes Jon, it's safe for Galvenized Zinc.
    I've been working with it for almost two years now and I've made a very mild wash concentrate. My first step was the salt deposit remover, but mild enough that it won't strip the surface while still removing the grime. My polish already does an excellent job at sheeting water, but anyone that boats in the bay is going to have salt deposits in any number of places.
    Removing Salt Deposits. Good!
    Stripping Polish. Bad!!
    You would also be surprised at the amount of harsh chemicals that are added to create heavy suds. That's the same reason I tell everyone to use something similar to Dawn(not RG3) to strip their surface of any previous wax build up if needed. My formula also takes a turn at Motor Flushing. We've always flushed with fresh water only, so since engine flushing requires additives that I don't find productive to fiberglass care.....
    Stay in touch!
    Donnie
    Charter Member Griff's Avatar
    Omaha NE
    Sounds most excellent Donnie.
    So it'll be half the price of a gallon of Muratic Acid?????
    Lake Ouacihta, AR.
    You're terrible Griff.
    Davis FSR, the blue stuff....
    Charter Member / Competitor RACESDAD's Avatar
    Indiana
    i will need samples asap please
    mike
    Donnie let us know when the cleaner is ready.....
    Lake Ouacihta, AR.
    We're shooting for mid February just in time for Miami.....
    I'll post up some more info as we get closer.
    I've had a few questions already, so I figured I'd post this up at least. My Hull Cleaner/FSR is safe enough to use while your boat is on the lift sitting over water, so no more pulling it just to clean built up scum.
    SO Tech Expert/Sponsor Mitcher T's Avatar
    Yankee Springs, MI
    Put me on your order list, too, Donnie. Your products are EXCELLENT.
    I'll see you in Miami. Are you going to have a display?
    Thats awesome Donnie can't wait to try it everythings else works great. Hope you guys had a good new year!
    Lake Ouacihta, AR.
    Thanks Mitch & Dustin!
    Mitch,
    I'll be in touch about Miami. Have something in mind.......
    Donnie
    Lake Ouacihta, AR.
    Available February 5th.
    Check us out at the Miami Show.
    Jim at Top Notch will have everything in inventory on the 5th & Mindi when we get to Florida for the show.
