Results 1 to 5 of 5
    Merc. 502 Oil Cooler, Rear Mount
    registered
    St. Petersburg, FL
    Exclamation
    I'm told I need one of these. It's the rear mount one, above the bell housing (not the low side mount). Anyone have a P/N or source. Thanks.
    I just looked on merc card and found many listed
    816082t old design with end caps out let points up 92 93
    817577t new design appears same in pic
    805561t1 shows p/s ports 93 95
    806423t straight thru type with p/s ports shown 93 95 efi
    849952t in and out lets point down with end caps 500 efi
    need more info, there are 3 support bracket choices
    registered
    St. Petersburg, FL
    Thanks Jim,
    No P/S on this motor, oil only. This is for a Gen VI 502.
    The gen IV '90 '92 oc878221-od824588
    used the 816082t and the 817577t
    The gen V '92 '93 also used the 817577t they both appear the same in the pic both have straps that attach to a bracket connected to bell housing , but bracket has a different #
    registered
    St. Petersburg, FL
    Thanks Jim!
