Results 1 to 20 of 22
    Hydromotive prop needs labbing?
    Registered B.Z.'s Avatar
    Evergreen Park, Il
    Easy question: I heard they do not lab there own props??? so who should I send them to????
    they are a set of P5X's
    Registered bajacleveland's Avatar
    Lakewood, OH
    I took mine to them and they sent it out to have done.
    Not sure to who.
    Registered kjm5125's Avatar
    Cleveland, Ohio
    A few years back I took mine in and they did the work.
    They do blue printing and lab finishing..
    They don't warranty any labbed props but not sure any one would.
    Charter Member Griff's Avatar
    Omaha NE
    Call BBlades. He can lab any props and will discuss your needs and give you realistic expectations
    Registered Gary864's Avatar
    Paridise north
    Call Hydromotive they do it 330 425 4266. As mentioned they do not warranty them once this is done but neither does anyone else as I undserstand it.
    BBLades
    Whats with all this Skater Nation nonsense?
    $48,900.00
    CHI-TOWN
    I'd call brett at bblades or julie/matt at throttle up. They should be able to do what you need. You looking for RPM BZ?
    Smile
    We do all our Labbing in house. We have the templates an can do them to fit your needs.
    Hydromotive sends them out to a local guy.
    920-295-4435 www.bblades.com
    Evergreen Park, Il
    Quote Originally Posted by bbladesprops View Post
    Do you have the stuff needed to work on the P-5X????
    Evergreen Park, Il
    yup-200-300 more and I am perfect
    St. Petersburg
    Just a quick note on labbing Hydromotives. We typically see 150-180 RPM increase on them, not 250 RPM as seen with other manufacturers props. The P5-X is a special case however. We stopped labbing them about 3-3.5 years ago. The propeller is already pretty thin....which is why it can hold its own pretty well right out of the box, stock. This does not leave much for the labbing process, particularly the thinning aspect. We also have seen a much higher failure rate with labbed P5-X propellers, regardless of the company that performed the initial labbing. This high failure rate is why we stopped offering labbing services of the P5-X several years back. The gains reported were minimal along with RPM increases as well. This is not to say that you cannot thin the propellers significantly and experience the greater RPM increases, but the failure rate increases as well.
    Food for thought.
    Julie
    GO FAST or GO HOME!
    CHI-TOWN
    I wonder how some labbed maximus would work on your hull BZ? I know they can be labbed, modified, with big results.
    St. Petersburg
    Now, the Maximus is a whole different beast....you can get some serious RPM out of them!
    Julie
    GO FAST or GO HOME!
    Evergreen Park, Il
    I already tried the Max...didn't like it at all I LOVE the P-5X just want that little extra!!!!!
    St. Petersburg
    Quote Originally Posted by B.Z. View Post
    Definately one of my least favorite propellers out there! The P5-X on the other was one of my favorite props when we sold them.
    Julie
    GO FAST or GO HOME!
    Evergreen Park, Il
    so leave them alone and deal with 5100 rpm's on 525's????
    St. Petersburg
    Do you consistantly see 5100, or is there some fluctuations within the season for you?
    Julie
    GO FAST or GO HOME!
    Evergreen Park, Il
    I could get to 5100 but it was hard, trim, water and everything had to be just right.....
    St. Petersburg
    So would you say that you can run 5000 RPM all day long?
    Julie
    GO FAST or GO HOME!
