Page 2 of 2 FirstFirst 1 2
Results 21 to 35 of 35
    SO Tech Expert Mrhorsepower1's Avatar
    Cleveland,Ohio
    call me next time.
    Temple, PA
    What is the GL rating and weight rating of the Merc Hi-Po Lube? Mobil One LS 75w90 gear lube carries an API GL-5 rating, and has served me well for 15 years. Bel-Ray makes very good stuff, by the way; we've used their shock oil in oour race cars inthe past.
    registered
    St. Petersburg, FL
    Yes, Bel-Ray makes some great oils and lubes. A great majority of the oils and lubes used in the aviation industry are supplied by Bel-ray. They are tops when it comes to industrial lubrication.
    I discovered that from the Merc MSDS sheet (see attached, last page). Now if we can only figure out which Bel-Ray P/N it is, we'd be all set.
    http://www.belray.com
    http://www.belray.com/industrial/pro...ar%20lubricant
    Attached Thumbnails Attached Thumbnails MERC HI-PERF GEAR LUBE MSDS.pdf   bel-ray lubes.pdf
    Registered Trim'd Up's Avatar
    STL, on the ILL side
    My uncle gave me a couple gallons of Belray Polar gear lube he got from work that I use in my jeep diffs. They use it in mining equipment because it is supposedly more water resistant. It's not green, its light brown though. I wonder if they just dye the merc stuff and jack up the price?
    registered
    St. Petersburg, FL
    Polar is a mineral-based lube. The blue stuff is full syn.
    Interesting, they're in Farmingdale, NJ. Nice!
    registered
    St. Petersburg, FL
    I'm fairly certain that the Merc blue hi-po lube is an SAE 75W-90 lube, which is the equivalent to ISO VG 150.
    The most closely matching Bel-Ray gear lubes are:
    (1)Bel-Ray SE2 Lubricant, P/N: 63700, ISO VG 150.
    Synthetic General Industrial Lubricant.
    A technologically innovative synthetic extra heavy-duty gear lubricant
    formulated for all types of gearing under severe temperatures and
    loads. Effective for plain and roller bearings. See Product Data Sheet
    for name grades, temperature ranges and application instructions.
    (2)Bel-Ray Synthetic Gear Oil, P/N: 66880, ISO VG 150
    Totally synthetic hydrocarbon and ester combinations exhibiting
    outstanding Extreme Pressure and anti-wear properties as well as
    excellent viscosity and temperature properties. This lubricant exhibits
    low coefficient of friction in addition to being compatible with mineral
    oils.
    registered
    St. Petersburg, FL
    I emailed them, and I'll wait and see what they come back with.
    Where the summer never ends
    Quote Originally Posted by Mrhorsepower1 View Post
    call me next time.
    U NEVER ANSWER YOUR PHONE !!!!!!!!!!!!
    registered
    St. Petersburg, FL
    This guy wasn't really very helpful.
    On Thu, Nov 5, 2009 at 2:45 PM, TSQ <TSQ@belray.com> wrote:
    Nick,
    We recommend you purchase the Mercury Marine Gear Lube as it is specifically formulated for the application.
    Regards,
    TSQ
    Temple, PA
    Sounds like BelRay makes it for Merc and isn't allowed to sell it direct or let anyone know...
    For what it's worth, there's a 53-gallon drum of Volvo Penta synthetic 75w90 GL5 oil on ebay:
    VOLVO-PENTA-STERN-DRIVE-BOAT-GEAR-OIL-SYNTHETIC
    for $1900 buy-it-now, or $9/quart. Group buy?
    I can get you a 55 gallon drum of AMSOIL Marine Gear Lube for around $1600. If you're interested, please let me know.
    I thought the Merc HP was a synthetic blend, not full syn.
    Temple, PA
    Quote Originally Posted by 07DominatorSS View Post
    Good price, but I get all the Mobil One product that I can use for free, so..... Thanks anyway!
    I have a skid full at 8.00 quart
    ron bender
    216-390-1330
