Results 1 to 10 of 10
    Mineral to Synthetic
    I just finished seating new rings on mineral oil (Gibbs Break in oil) and am about to go to full synthetic.
    I was told by my Cylinder head specialist that he just heard that if you don't completely remove all the mineral oil, the cylinder walls will "glaze" and you will loose your ring seat. This was from a Gibbs tech.
    He mentioned Amsoil recomends the same but for a different reason (He thought it reacted with the synthetic, gumming up passages).
    I have never heard this before. Since I did not seat the rings on the dyno this time, I would have to completely R&R the motors to get all the mineral oil out.
    Sounds a bit out there for me, any other opinions out there?
    Cause somebody has to!
    Considereing that just about every syn maker out there claims "compatability with mineral oil", it seems a little out there to me claiming "reactions" between them doesn't it?
    PS, I run the Brad Penn Racing semi syn. Got both bases covered
    By federal law, synthetics and mineral oils must mix! i.e., if you were in the middle of nowhere, and could only find one or the other, it has to mix, so you wouldn't be stranded. Go right ahead and change the oil to a synthetic, its not going to glaze the walls, nor, lose the seating.
    P.S., Airpacker, do you know what semi synthetic means? Or how much synthetic properties that oil has, or is required to have? I'll answer that for you, less than 1% is required. A semi synthetic or synthetic blend oil, can be basically the same thing as adding one creamer to your coffee in the morning. Unless an oil says 100% SYNTHETIC, and not "full synthetic" like Mobil 1, its not 100%. So, in other words, semi synthetics and blends are just a marketing ploy to make you spend more money, for not really any better of a product than the petroleum products.
    Quote Originally Posted by 07DominatorSS View Post
    Where do you see that? Not bashing, just curious.
    Read the bottle, its not 100%, it's a "full synthetic", which is a highly refined petroleum based product with synthetic base stocks, specifically PAO's, blended into it, to make it a "full synthetic".
    My take is simple. This oil
    http://www.bradpennracing.com/default.asp
    was recommended by several top engine builders from here and the USA. If its good enough for them, its good enough for me.
    Oh, its also 1/2 the price of mobil1 and considering I change it ( 12 quarts ) every 10 hrs, thats a good thing.
    Quote Originally Posted by Airpacker View Post
    Well, I guess I prefer to use the best products I can find, considering I have about 40k worth of motors and drives! To each their own, but "good enough", is exactly what it says, just good enough. Personally, if Mobil 1 or AMSOIL was 5 times the cost, it would be worth it still. But, hey, once again, to each their own.
    Charter Member Griff's Avatar
    Omaha NE
    How much is the Brad Penn Oil and where do you get it????
    I get Mobil 1 15-50 5qt jugs for $22-24 at Walmart. Readily available any I need it and that one thing I like.
    Penn racing oil is heavily loaded with zinc and phospherous. It is used by many successful race teams on land and water. My engine builder ( the best and most successful in Canada ) recommends it. Crocket recommends it. Most major cam manufacturers recommend it. Does that mean its just good enough or do you think maybe these people have a clue?
    PS, I run it in a 900 hp, 6000rpm blower motor. Not exactly a cheap piece I would trust to your average off the shelf oil.
    My cost on the BP racing 20w50 is around 6 bucks a quart or 72 an oil change. My cost on Mobil one is 37 bucks a 4 litre jug ( thats about 4.5 quarts) or 98 bucks an oil change.
    I order it by case lot from an importer.
    Wally mart here stopped carrying the 15w50 Mobil one a couple years back.
