Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 72 of 72
    Registered tsp's Avatar
    Toronto
    ar15meister,
    Forget about the tv shows and the moving you got the sweetest 28 around. Get that Ebony girl patched up and bring her down to Lake Ontario.
    Even better, I'll save you the trouble of putting it back together and trade you my 24. It got a new transom assembly and is ready to rock. Been out twice already. Kicked a Baja 240's ass the other day.
    Quote Originally Posted by rexx28 View Post
    Alan make shure your engine builder checks the wall thickness on that block, Bisoff had told me next rebulid I should consider a new block, Jeff
    Jeff,
    Good to hear from you pal. I am taking care of it as best I can. I will touch base with the guys building the engine regarding the block but they told me the block and the crank are in very good shape. They had nothing but good things to say about Tony's work and arent doing much different except a few little things. I got 2 years out of it before it blew up so thanks are in order lol.
    The carbs were set up a bit strangely, having some parts from both 750 and 850. Airpacker told me that there was a reason for this but what the reasoning behind the setup was isnt apparent. It would be interesting to know.
    As far as speeds, the boat ran between 78 and 82 before depending on conditions and fuel, passengers, etc. I am sure there is more in it but I wont really know until I wire in the GPS speedo and I can phuck around and see without using the handheld.
    Registered slpcamaross97's Avatar
    Feb 2009
    Lapeer, MI
    Looking good......
    also, snapped a couple pics of my new '76 Eldorado when I was visiting my old man the other night.
    another one I was lookin at earlier today thought you guys would like. my old man had a few of the hot rods out this night.
    Registered tomcei's Avatar
    Atl. Ga
    sweet. you guys got it going on!!
    Registered blackhawk's Avatar
    Jun 2009
    Quote Originally Posted by ar15meister View Post
    Is that a Roadrunner?
    Quote Originally Posted by blackhawk View Post
    a12 Roadrunner.
    Registered Mikeb4's Avatar
    Michigan Thumb
    Going with some tricked out bowls??
    Quote Originally Posted by Mikeb4 View Post
    I am going to try and make it look a bit nicer than it did.
    LI, NY
    btw, not many boats can pull off a dry exhaust...
    fortunately, yours is one of them.
