Anyone out there swap out the heavy steel Merc driveline for an aftermarket aluminum or even carbon fiber driveline?
Seems that they have been race proven in many other arenas and in my boat, it is a straight line application, no angle at all. Could probably even eliminate one of the u-joints.
Any opinions out there?
Thread: Aluminum Driveline?
Results 1 to 20 of 62
- 1,027
10-19-2009 11:20 PM32' Fever (Off to Syracuse) and 36"Gladiator; FORD powered
Cause somebody has to!
10-19-2009 11:21 PM
yes. carbon will survive moderate power/not to rough/not to big of boat.
nothin beats a steel one in big power/big water conditions.
- 1,027
10-20-2009 12:09 AMIs there a reason to have a slip joint in the driveline if the distance is fixed length?
How about a u-joint on each end if there is zero angle? Both Needed?
.32' Fever (Off to Syracuse) and 36"Gladiator; FORD powered
10-20-2009 12:37 AM
the probability of actually having a dead nuts zero angle is slim multiplied by any flex... you may get it close enough to live but it will fatigue and crack eventually unless you are running a rubber coupler. I have seen video of a boat running hard without the engine hatch... the motors move.
- 1,027
10-20-2009 01:55 AMI do have rubber couplers...Bravos.
Not perfectly zero. There is approximately .005" of "pivot" of each u-joint in a complete rotation. I am just wondering if 1 u-joint is enough.
10-20-2009 02:14 AM
are you attempting to gain something by eliminating it? the actual mass given the diameter is fairly small....
10-20-2009 02:47 AMOffshore Racing wasnīt designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
- 37,354
10-20-2009 06:51 AMWeight is weight.
I don't know for sure what they ended up doing, but if you get ahold of Keith with the Cat Can Do team they use aluminum in their Super Cat/PX Cat. It broke at St Clair this year, but they had it repaired and they ran fine. The new blower motors they run have a lot more power than the old SuperCat engines use to have, so their opinion should be a good one. CK Motorsports in Spring Lake, MI. Keith Holmes. Plus he's a certified Mercury Mechanic on the big drives.Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- Where the summer never ends
- 4,346
10-20-2009 09:31 AM
god knows i hate to say this,,, dd is right,,,damn it,,,, you need at least 2 o of angle in a u-joint so the needle bearings inside the cups will rotate , otherwise they stay fixed and pound flat and vibrate and blow out, those little needle bearings spin in the cup and reduce friction.(hp) and i did see carbon fiber driveshafts yesterday on 700 hp and a 39' boat ,,, god please save me.....lol
- 1,027
10-20-2009 03:04 PMYes, I am thinking weight. My small driveline is probably 50 lbs and it is only on the one side. I have seen drag race drivelines in aluminum and CF advertized "good to 1200 horses" which is much more than I have, so I was thinking......
On the angle....my bad. I am not going to move the engine now so I will just have to replace the u-joints on a regular basis.
10-20-2009 03:16 PM
The aluminum may work just fine but, it will need to be inspected much more often for cracks. I personally don't think it is worth the risk in a pleasure boat. I have seen an aluminum one fail. It sure does make a mess. It let go with out any warning or vibration.
I to agree a small variation in cross bearing angle is preferred. The slip spline coupler makes service easier and allows for boat movement. Any end load transferred in to the engine will cause crank failures.
10-20-2009 03:28 PM
The guys who have run all 3 prefer either the steel or carbon, the alum not so much.
If built to the right spec, carbons work flawlessly. Just don't repower your boat with nearly twice the torque and leave the orginal carbons in there (ask Miccosukee).
- 4,346
10-20-2009 04:06 PMThe likelihood that you got the engines in perfect alighnment is pretty slim. A degree or so isn't much. You should be OK.
On the aluminum shaft, the reason they have issues is that aluminum work hardens. On something like a roadrace car, you're not going to get dramatic shock loading like you will in a boat that's loading, unloading and sometimes reverse-loading the propeller. The first thing is to have it constructed from the proper grade of aluminum. Then after welding is should be re-heat-treated. 6061 is probably the best material if you need aluminum.
On the slip yoke, you absolutely need it. There's no way you can get the spacing to a thousandth or two and the engine mounts will flex, not to mention the hull/stringer/transom.
- 1,027
10-20-2009 04:27 PMThe merc input shaft assembly has a .250" back and forth ability. I assume the additional 2 inches in the driveline slip yoke is also needed?
10-20-2009 05:07 PMThere's a fixed flange on the back of the engine and a fixed flange on the transom plate carrier.
- 4,346
