I bought a set Keith black Oldsmobile DRCE aluminium engines ,they are Bandit racing engines ,632 ci ,dry sump ,jesel valvetrain ,solid rollers ,power is 1000-1100 hp ,rpm ,s were 6500-6800 according formal owner .
How about using one for in my SR 24 HTM ? would the lightweight engine be better ,or does it make not much difference in this type boat ?
Thread: HTM engine
Results 1 to 20 of 27
- Jan 2009
- 107
10-10-2009 05:07 PM
10-10-2009 05:26 PM
Problem is those are Drag motors.... they wonīt live in a boat at leasty with the camshafts thats in It I reckon with a big overlap.
Light is always right but in the right places.Offshore Racing wasnīt designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
- 37,354
10-10-2009 07:59 PMYou'll have issues.
RPM of the current setup is too high for a Bravo drive. Depending on the power curve, you should probably not run it over about 6000rpm. So, cam change needed. As Mika said, probably need that anyway to fix the overlap unless you're running dry exhaust.
You need to know the compression ratio at boost to know what fuel to run. On the water is tough to get high octane.
You will most likely need to marinize the engine changing to brass plugs etc.
Other than that, I think it would be cool. Does that boltup use the same pattern as a big block Chevy?Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
10-10-2009 08:36 PM
It looks like they might have been in a boat. Looks like marine water hoses and flame arresters. Not sure why the high r's are are a problem with bravos. I would be more concerned with how low they will idle. They need to idle below 1000 ideally lower to shift. I have seen sillier things done. Were they boat motors? Do they have chevy bolt pattern on back? What exhaust do you plan on running?
- Where the summer never ends
- 4,346
- Jan 2009
- 107
10-11-2009 04:15 AMThese engines were in a Skater 36, with # 5 drives ,the exhaust bolt pattern on the heads are BBC style (EPD racing heads) the tranny bolt pattern on the block is GM style and Chrysler style ( 2 bolt patterns)
I was plan to use a Speedmaster #4 that I have on my shelf ,I was also unsure if a bravo would work ... the engines idle at 1100 rpm ,exhausts are Stellings big tube I was hoping for 125 MPH in this HTM cat ,do you guys think thats possible with this engine and # 4 drive ???Last edited by sterling; 10-11-2009 at 05:09 AM.
10-11-2009 07:21 AM
Are you sure these ainīt marinized Drag engines ??
I mean the parts you list would make me think that way...DRCE alu block, all out Oldsmobile Pro Stock heads that flow up to 8000 rpm or more if needed tunnel ram with Dominators. Sounds like Pro Mod right there...
Put the SSM on that cat and Hang on and pray is all I can say...
Thatīll be a wild ride for sure....Offshore Racing wasnīt designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
- Jan 2009
- 107
10-11-2009 07:58 AMBandit racing has a website ,they use to make engines based on a DRCE block ,they are true offshore engines build from the begin .
They were in a 36 Skater that was converted to pleasure deck ,but was originally a twin canopy raceboat,I do believe its the same boat as on Bandits website .
- Jan 2009
- 107
- 37,354
10-11-2009 08:11 AMCool, run them. That will be a heck of a ride.
What does your HTM have in it now? It has a #4 drive??????Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 37,354
10-11-2009 08:13 AMBy the way Jim, good eye on the fittings......
But you think a Bravo will live at 1100 horsepower and 6800 RPM?????Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 37,354
10-11-2009 08:15 AMIf you use one. How much you want for the other??????
10-11-2009 08:39 AM
+1 for JIM.
I Think Mange on the board and the other Arrow guys are pushing it close. Mange at 900 and then thereīs this other dude with an Arrow830 that has a 1025hp Blower engine...
So they at least should know if thereīs any left.
With a Cat that could be possible but it still would be a short fuse IMO.Offshore Racing wasnīt designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
- 4,346
10-11-2009 09:39 AM632" at 6500+ isn't going to last very long. Even with the best stuff inside. The CID/RPM/horsepower you're talking about says they're going to need race fuel which is expensive and inconvenient at best. Those heads were originally developed for pro stock class racing. They're not going to be all that friendly at low RPM's. Those large ports mean big power up top but low intake velocoties at idle and low RPM. That means the fuel will fall out of it's atomized state and puddle, causing plug fouling and rough low/mid rpm running.
The SSM IV was engineered for about 750 hp. It'll work, but not for long.
These are race boat engines, not pleasure boat engines. You can use them, but you can also keep a Bengal tiger as a pet. It's cool, but it's got alot of downsides.
- 4,346
- Jan 2009
- 107
10-11-2009 10:40 AMI was only thinking about using one in my HTM,I have a 518 ci with blower and intercooler too ,that might be a little easier ,anyway the HTM was set up for bravo 1 ,so my idea was to use the #4 instead ,cause I feel by looking at #4 its a much beefier drive ,gimball is much thicker and the gimball ring is massive compare to a bravo.
The #4 was indeed rated at 750 ,but back then wen there was no # 5 or #6 ,they used bigger engines on a #4 ,just like they did on a bravo 1 when there was no XR drive .
We had a 1100 hp twin turbo engine on a 28 ft boat with a #4 ,and it never broke ,at least not with us .
I have to redone the HTM next year ,because it is in bad shape ,the floor is rotten ,so I have some work to do before I can put any power /drive in.
10-11-2009 10:46 AM
Could you post some pics of that Twin turbo engine, maybe an own thread about Turbo marine motors even..
- 4,346
10-11-2009 10:54 AM
10-11-2009 11:21 AM
Well Said Chris.. look at my post, #7...
The Olds/Buick/Pontiac DRCE Pro Stock heads flow around 420cfm at .500" lift and 28" vacuum.
An Ordinary Square port 188 head flows ca 365 from a LS6/420 Merc 454/ 365 Magnum/454 HO.
Still those Square ports doesnīt either work properly until ca 4000 rpm and not even then has cought a normal big oval 454 head especially if done with big valves.
Those ovals can go up to 650 hp and 6500 on a 502 also and flow only around 300cfm at best.
So those heads are even IMO for a 632 overkill unless you drag race.
the lesson here is itīs allabout velocity not a big flow number...Offshore Racing wasnīt designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
