Results 1 to 3 of 3
    Wire a GPS unit?
    On an 06 25 Outlaw where do you run the ground wire? also what are you useing to power the unit? Thanks in advance
    Annapolis, Md
    Look for a ground block behind the dash. A lot of times manufacturers will run a positive cable and a negative cable all the way to the dash area to tie into. Sometimes you wont find a positive block. If not you can either wire it hot to one of the switches, or if you have a unused switch or location for a switch tie it into that.
    Don't tie it into an existing switch on the switched side. A Gps probably doesn't draw that much but you could over load the switch.
    2005 Formula 330ss
    Bradenton Fl.
    run both direct to batteries with a fuse on pos. right at batt. You will never have a problem with interferance from other electical units that way.
