On the technical side, there is no easy explanation, except for that my boat was built for the F1 class, Jim Simmons was built for F2 we are both in no mans land in between speeds. Going by the old adage of "Build a boat for the class, not a class for the boat" and that P3 is also no longer in existence, this intern forces a F1 to run against a F2 boat. Chicken on the other hand has a boat built for F1 but has replaced the motor and made some other changes to make it a P4 boat. What makes my boat uncompetitive in P4 is anyone that has seen a dyno pull of a 500EFI knows about the torque curve. In the race I had the lead from the start to 78 mph and they caught me and said cya. I crept up to a max speed of 82.4 mph as the race progressed.
I applied to run in P5 due to pulling both rosters, made a spread sheet and with 4 other boats registered have the same hp as my boat(and approx the same length) With my boats documented kilo speeds they said no sandbagging will be allowed and bumped me up. Unfortunately, unless we run at Chattanooga every race you will never see my boat run in the kilo setup and is apples and oranges between my race and kilo setup basically 7-10 mph difference. I am not complaining by any means, just answering your questions Paul as how they deemed my application. I am glad that SBI bumped me up and we had a great shake down and a lot of fun with the gang again. I'm really not all that great at GPS staring so it worked perfect for me and let me do my job instead of computer racing. I would much rather get beat by other racers than have to compete with a computer. Now all I have to go is go out and spend $27 on filters and plugs(oil is already here) and I am ready for Key West.
Side note, DD you had no idea that you finished 3rd until they posted times on the trailer and I explained to you that I didnt exist, so to speak. You crack me up, but then again there are only two ways that you'll ever beat me: 1) get another boat 2)in your dreams.....
Thread: Clearwater Unofficial results
Results 61 to 80 of 142
10-06-2009 12:36 PM
- 37,370
10-06-2009 12:43 PMNice Trash Talk, love it...
I still don't have a good answer as to why Trent could not run P5 though. How do they determine? I thought it was strictly maximum speed obtainable based on prop pitch etc. What is the criteria for disallowing his application? Just that in Kilo trim the boat can go 85??????Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
10-06-2009 12:44 PM
- 37,370
- 37,370
10-06-2009 12:54 PMI mean it's like when we ran the Batboat in St Clair and Harrison in P5. All the Batboats were in P6 at 70mph. We ran P5 at 75. Our best test speed was 84 with the boat maxed. Tyler's boat runs over 100 in Kilo trim, but with his testing, chipping, and propping, he runs extremely well in P5 and accelerates tremendously. Makes it very tough to beat him, or even keep up.
I believe to beat him I'd have to build a twin outboard Vee with the 2.5's, or a duoprop Batboat with an all aluminum bigblock......
But, still trying to figure out why Trent was not allowed to run P5. What is the proceedure for the result? Who knows exactly???Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- Where the summer never ends
- 4,346
10-06-2009 01:00 PMbut then again there are only two ways that you'll ever beat me: 1) get another boat 2)in your dreams.....[/QUOTE]
WE WILL SEE ABOUT THAT.
Ask your wife,,she told me diffrent. HAHA
10-06-2009 01:20 PM
Exactly!! Global Warming ran in P2(105) on the Production side in Clearwater. SBI is doing away with sandbagging(propping down, etc) They are putting boats in classes by what the boat can do maximum. Will it work. I dunno, but we shall see.
The major disadvantage I have going against me is that my boat is totally documented in the SBI office from the dyno sheet to the kilo records that she holds. No other P class boat has that kind of paper trail.
10-06-2009 01:28 PM
10-06-2009 01:32 PM
10-06-2009 01:49 PM
Thanks Sean.
Good thing Cat Killer doesn't have to race Cat light.
There is no reason why other than some hurt feelings that All those twin V's don't race together power to weight in ONE class.
Than reliability would become an issue and the shootout motors would lose their allure.
10-06-2009 02:16 PM
Actually We both agreed on that right at the turn bouy when I told the engine is not getting ANY rpmīs like it did in Testing and felt something is **** creek.
Just after that we probably both looked at the same time at the Trim gauge and was all ??? and called it quits.
I Didnīt wanīt Scott to MISS KEY WEST because now we know it can be fixed to run again.
Donīt Bash Scott as I was OK. Im used to everything going wrong in RACING since 1983 with the ASA Late Model Firebird I was wrenching then and thereon.
Guys Thatīs Racing that a 1$ part goes out on you.
I still had a GOOD Vacation thanks to Scott, Petra And Buddy !!!
I mean Im Hooked 4eva and If itīs up to me well get the DAREDEVIL TEAM up to 2 Boats if we just do some work for it together.
* then we can Sandbag Trent easily You know I of all people in the pits do now about TEAM orders in Racing.
Iīve been in teams so many times that got beat by them and finally I decided I you canīt win them join them and eek out all the tricks in their books...and still be even friends with them.
Now Thats Sisu for you...Last edited by MikeyFIN; 10-06-2009 at 03:46 PM.
Offshore Racing wasnīt designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
10-06-2009 02:29 PM
Well Mika, You are a good sport. I am happy to hear you enjoyed your self while here.
I only commented after he invited the smack talk. Are you going to race with him in Key West?..
Trent now that the results are posted I understand. You got 0 points just like we did in Sarasota.
10-06-2009 02:35 PMOffshore Racing wasnīt designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
10-06-2009 02:41 PM
Well you Know Scotty, heīs almost as bad as me shooting bull...
No Iīm not Racing as the seat is gone for another Driver and I actually wasnīt sure If can come over, darn Work...
But Iīm looking into to come just over and do some Wrenching for the boat there so Itīll RUN !!!
We know the Issues and Scotty has the main parts at home to get it really to kick butt like it has done.
That boat is Rock solid, you can throw it at any water and it just eats it up considering itīs size.
I mean it aint a 47...Offshore Racing wasnīt designed to be a spectator sport, it's for people or companies with's lots of money to push the envelope of endurance technology and hopefully put a trophy on a mantle. It's man vs the elements, not like boats with like engines running in circles.
10-06-2009 03:13 PM
Nice. I hope to meet you if you make it.
- 4,346
