Results 1 to 3 of 3
    Trailer Jack...Parts?
    Registered Shah Mat's Avatar
    Potomac River, VA
    Fulton jack. Magnum series, 3000 lbs.
    The handle must have fell out on the road somewhere. Anyone have this happen? Any luck getting pats and fixing it? I found a Fulton catalog but I'm not sure what I need and where to get it.
    http://www.fultonperformance.com/Jac...gs26-32-08.pdf
    All over da place.
    Joey,
    Try http://www.championtrailers.com/
    Worst case, pick up a new one. You ought to be into for less than $100 bucks.
    wwwActiveThunderBoats.com
    Toronto
    If the handle is removable you can prolly just buy a new one, but if it snapped off it might have damaged the internals. We had a boat trailer that had the jack mounted really far up and it use to break it if you took a real sharp turn. We ended up just saying screw it.
