Results 1 to 3 of 3
    350 Merc Mag Intake Man restrictors
    Tampa Area
    Putting the new block back into the Formula. The intake manifold gasket sets comes with a SST restrictor plate, for the center port.
    Based on the "directions" some motors needs the restrictors, some don't
    Replacement motor is an 86. 350 V-8. I think it's a 2 main seal and have the valve cover bolts in the middle. Do I need the restrictors? or not?
    Also.. since it is NOTa closed cooling system, does the thermostat needs to be installed? I know the T stat restricts water speed, but since it is always "raw"/sea water, do I need it?
    Thx
    P
    I looked,, not sure on the restrictor. What type choke does it have electric or the coil thing? The coil thing needs the cross over open I believe.
    The 82 -86 card shows a 1 piece main seal and early valve covers. The 87 shows 1 piece seal and top bolt valve covers. ???
    You always need a thermostat. With out it the cool water entering can run right out. It will give a false low temp reading while not forcing water to the rear of the motor.
    Tampa Area
    THanks. I will put in a T stat.
    What I know is that in 86 there were two options on the valve cover bolt pattern. I have the 4 bolts in the middle, but the main seal seems to be the 2 part.
    The choke is the srping type. THe flywheel plate is a strange shaped thing, Not cymetrical (or round, somewhat a round and rectangle combo) like in the later models.
