I remember actually seeing the windshield turning brown and then poping. The next thing I remenber is sitting in the boat with water up to my waist looking up at the Helo and thinking I shouldn't be able to see the helo! Then Dave woke up from his nap and we restarted and still took 3rd! We were only about 100 yards from the checkered flag.
Results 61 to 80 of 176
09-16-2009 11:40 AM
09-16-2009 12:15 PM
That is the standard Milspec test as demanded by the government. Texstar still uses that cannon.
THe reality is the canopies will flex acceptably under almost all scenarios. the problem is when the impact is up against a sheer point....or a metal support.... the canopy has no where to flex and it tears (sort of like being put into a "Break"....... another case for no internal roll cage on a traditional f-16 canopy.
T2xAllergic to Nonsense
09-16-2009 12:20 PM
09-16-2009 12:22 PM
Those internal roll bars on the seat two seaters behind the window is just a bad band aid anyway.
09-16-2009 12:24 PM
While the F-16 design is fine for this style of boat....the speed is much lower...and the impact dynamics much lighter than on a full sized cat. Champ boats have small, almost tear away canopies that are fine because the boats are so light that they "bounce' off the water's surface in most cases. When they do "stuff" the deceleration is a much bigger problem on the driver's body than the water intrusion.
- 37,359
09-16-2009 12:43 PMSince you're on and paying attention. Wouldn't an end-grain balsa core, new high-tech glass, laminate be stronger in a canopy (and lighter) than just layers of glass to a certain thickness? Or am I all washed up here????
09-16-2009 12:52 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
- 37,359
09-16-2009 12:58 PMI know this sounds stupid, but, when I raced and ran record RC boats. The strongest, and most flexible, program we came up with was carbon/kevlar weave glass, balsa cored, epoxy, vacuum bagged. In a crash they would destroy other boats, in a blowover approaching 100mph no big issues. And they were extremely light. I have a 54" Vee in the garage now that is less than three pounds with everything but motor. Stringers were built the same way.
- 37,359
09-16-2009 01:07 PMSo what core if not balsa?
09-16-2009 01:12 PM
Yes but the Ocean is a game changer the lightest boat I have built to date is 488 Kg 36' x 9' Cat with tanks.ready for nuts and bolts, I have an S glass/ Carbon Fabric nowadays and I can do a little better with the newer material.
I have some material testing on You tube.Slippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
09-16-2009 01:14 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
- 37,359
09-16-2009 01:31 PM
Here is some material testing this is old stuff.
http://www.youtube.com/watch?v=DRzyw0Jo8ZgSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
09-16-2009 02:05 PM
Steve-
When I removed the canopy on my Jag it had carbon and multi-ax cloth.
Rick-
Whose windshield will you use?Last edited by Dueclaws; 09-17-2009 at 09:57 AM.
09-16-2009 02:25 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
