We have a 25 Outlaw with a 502 mag. We are running a right-handed 22 Bravo I. I am curious where everyone sets the tabs when running. We are at LOTO, so it's usually pretty rough. With a normal load, I usually have the port tab about halfway down on the indicator and the starboard a little less than that. I also have to turn the wheel a bit to the starboard to run straight. Is this consistent with the other 25 Outlaws?
Results 1 to 7 of 7
- Dec 2008
- 8
09-09-2009 10:16 PM
09-15-2009 11:11 AM
I usually have the port down also depending on who is in the boat and the other all the way up it all depends on the water conditions. On turning the wheel I don't have that problem
- 37,337
09-15-2009 11:15 AMAre you positive your indicator is adjusted correctly?
09-15-2009 11:19 AM
Many boats need more port tab. The motor rotates to the left. I personally prefer a left hand prop on single motors.
09-15-2009 02:55 PM
yes i have to use some port tab and yes i have to turn the wheel a little.
- St. Petersburg, FL
- 3,965
09-15-2009 03:17 PMI rarely, if ever, used the tabs on my 25 Outlaw. That boat had enough hook in it that tabs were wholly unnecessary in all but the roughest of conditions - in which case I would drop them to neutral or maybe one notch past neutral. I never really noticed any prop torque effects on that boat, I though it rode level inherently. On occasion if I was dealing with a stiff cross wind or some nasty quartering seas I would drop one or the other depending on direction.
