Thread: Dash panel
Results 1 to 6 of 6
    Dash panel
    South Jersey
    Dave the panel by the shifters keeps coming loose.The original screw broke and I was able to put two others in but the keep backing out.What can I put in the seam before I tighten the two halves together so it can't come loose. Thanks Tim
    on the moon . . .
    maybe some 5200?
    maybe some 5200?
    As long as you never wanted it apart ever.....
    South Jersey
    Thanks will get some and use sparingly.
    can you through bolt it with washer and nut?
    South Jersey
    Quote Originally Posted by Toasty View Post
    Was not really enough there to do that.Used some 5200 problem solved.
