My boat is a 2000, its a 30' cigarette. the paint is in really good shape... my question is can i apply a compound to the boat, then wax, and not hurt anything......
if not, what should i do, there is no oxidation or anything, i just feel like it needs something a little more than wax to bring the "pop" back
Thread: compound/wax, when?
Results 1 to 20 of 28
- Jan 2009
- JAX FL
- 201
12-12-2009 11:17 AM
12-12-2009 11:49 AM
You could use a light compound at this point to bring it back. I wouldnt use anything to aggressive till it needed it. Check with MarineClean Donnie and see what they have. I've had great luck with their stuff.
Is the boat paint or gel? It will make a difference in what products to use.Throttles- Cleveland Construction/Traffic Light Racing 377 Talon cat
- Jan 2009
- JAX FL
- 201
12-12-2009 12:24 PMThanks Dave, i was hoping you'd chime in
paint
- Jan 2009
- JAX FL
- 201
12-12-2009 12:56 PMwhat do you think of 3m compound?
12-14-2009 02:45 AM
3M makes a lot of great compounds. You need to make sure you get the right one for your job. You could probably just use some Meguiar's Paint Cleaner with a foam compounding pad.
- Jan 2009
- JAX FL
- 201
12-15-2009 08:05 PMso dave what should i use?
12-15-2009 10:43 PM
is it gel or paint? if paint i would use one of 3M's products and as Griff said choosing the right product is important. I use Pefect it 6064 for light polishing, if you need somthing that cuts more use 6085(either with foam pad). For gel use Marinecleans oxidation remover followed by the waterless polish. I prefer wool pads for gel.
- Jan 2009
- JAX FL
- 201
12-16-2009 12:17 PMthe boat is paint, and i wouldnt say i need any MAJOR cutting, for a 2000 the paint is in great shape.... Just something to bring back the "kick", and the i planned to also wax it with the 3m Wax
- Jan 2009
- JAX FL
- 201
12-16-2009 01:58 PMDave- if you happen to chime in, let me know the best applicator pad to apply the suggested compound
- Jan 2009
- JAX FL
- 201
12-16-2009 09:01 PMim thinking perfect it?
12-16-2009 10:04 PM
yep the 6064 Perfect it should work great on that, I also use the the 3M white foam pad. My boat has a painted deck and to tell you the truth i only wax it maybe once or twice a year. It gets treacherous to walk on after a fresh coat. I just keep it clean and spritz it with McGuires spray detailer every time i'm out with it.
- Jan 2009
- JAX FL
- 201
12-17-2009 09:25 AMDave- Sorry to keep bothering you, and thank you so much for the advice... but what is the difference with perfect it 6064 and perfect it 6060
http://www.westmarine.com/webapp/wcs...9&classNum=549
http://www.detailsupplyplaza.com/3m6...ver-quart.aspx
- Jan 2009
- JAX FL
- 201
12-17-2009 10:14 AMfrom what little i can gather, the 6064 isnt really a compound, more of a step after the 6060, more like a polish?
12-17-2009 04:06 PM
correct its a follow up after compound, I use 6085 to buff freshly painted stuff and follow up with 6064. 6060 is a pretty course cutting compound and the 6064 is a final polish. If you have slight oxidation or light scratches use the 6085, it leaves a nice finish that you can also go straight to wax over (smells nice to
The only time i use 6060 is if i have to buff something out of older cured finishes like sand sctraches or if i let a fresh paint job cure to long before i color sand it.Throttles- Cleveland Construction/Traffic Light Racing 377 Talon cat
- Jan 2009
- JAX FL
- 201
12-17-2009 04:10 PMwith the 6064, can i still wax right after?
- Jan 2009
- JAX FL
- 201
12-17-2009 04:15 PMim overanalyzing this entirely too much..... but ive got the time to do it right so i want to make sure to pick the best product.... what i have is the boat pictured above, there isnt really any oxidation, there are some parts that are just duller than other... it needs something more than wax, but not a full blown compound
12-17-2009 04:17 PM
have you tried a clay bar yet? or do you want to use a buffing wheel on it?
12-17-2009 04:26 PM
I've used the 6062 with good results. Not as harsh as the 6060, but still a cutting compound. Designed to remove up 1500 grit sand scratches with a foam pad. I used it and waxed right after without using a swirl remover first. BTW, that West Marine price is way expensive. Try to find an autobody supply place. I paid about $35 for the same size bottle.
12-17-2009 04:33 PM
you should probably use the 6085 then, sounds like the condition of you paint falls right between 6064 and 6085. If it was mine thats what i would use, 85 is not THAT course and i'd hate to see ya waste time and not have any results to speak of. I hit the Donzi with 85 and go right to wax all the time. 64 is a pretty fine polish, heck you could follow up the 85 with it if you wanted to.
- Jan 2009
- JAX FL
- 201
12-17-2009 04:52 PMALright, last question Dave, im going with the 6085, but which applicator pad should i use?
