Hey Ian,
Sorry I missed you. I am usually at the boat shop during the week after work, and on Saturdays. I usually head to the lake on Sundays to relax. I will definately stop in and say hello if I see you outside. Seriously, if you need a hand with anything to get your boat going, I am more than happy to help, so don't hesitate to ask.
Tommy
Thread: 39' Chris Craft Scorpion Rebuild
Results 61 to 64 of 64
06-29-2010 08:32 AM
06-29-2010 10:01 AM
Feels like it..Working on them since the early 80's.
I am just rounding numbers in general. 1.5 or 1.6 inches doesn't matter much in this case. I do recall shorties listed..
Prop heights are easy to measure.. Parallel prop shaft to bottom. Use a straight edge to measure height in line with gearcase. In order to get an accurate number you should first make a mark on leading edge of case so the straight edge can be on a line exactly in line and parallel. The mark can be measured from the cavitation plate to the dimple of the prop shaft in the rear. Mark the same distance on the forward edge.
Paul, On mine I will only raise it to the rub rail.. I am not going to cut the rail and get all silly. I do not want to modify hatches either. Its just an old pleasure boat..
- 37,466
06-29-2010 05:52 PM
Tommy , sure was great putting a voice to the name along with talking with you today......Artie
