here is my motor on the dyno . how fAST DO YOU THINK????? http://www.youtube.com/watch?v=eL8i0Tnw7Qk
Printable View
Whats your boat weight?
BOAT IS 4000PD TWO WEEKS AGO IT DID 80.4 MPH WITH 600HP
Pretty fast for that hull. Becareful.
Nice job. Be careful with all that pushing a 24'.
I've seen test showing how much hp to push a boat 1 mph, and it seem to always adds up to 20 hp for 1 mph. which would increase your by 5 mph. my guess would now be 85mph
Bob, I would think 85 or so. Raising your x would make a huge difference in speed and handling. I would be a little nervous running that fast trimed up with the stock drive height. My boat is more stable now at 74 that when I ran 68 with the stock x.
Also, what drive are you running. You are pushing your luck with the Bravo.
Bob , seeing that you are running 700 HP you are going to have to change your screen name to bajabob 700 and drop the 600 ;)
I had the same boat to 91 gps with me and a buddy in it with more throttle left. My engine made 711hp on the dyno. The X dimension on my boat was raised 3 1/2"s, all of the wood was replaced with coosa, and the cuddy was stripped so it quite a bit lighter than stock. The boat is running 75+ with a stock 502 mag now so the weight savings made a difference.
ya i am runnig a136drive with a 25mirage with the last motor
http://www.youtube.com/user/SuperBaj.../0/XKQj2fy91BU here my boat runnig at the dock
i see 85-86ish in my 24 running what whipple says is 650hp with a 4 inch raised x, extension box, and 2 inch shorty running a labbed 32p 5 blade
wow that great did the 4in lift help alot?did you try your boat with out the 4in ? and if you did wt speed did you get out of it . i am still tested and like to go in the rigth direction:cheers2:
i bought the boat as is the previous owner said that with the old motor a procharged 502 with a stock bravo 1 stock x dimension and single ram steering said it was low to mid 70s and was fairly unstable
its a imco box ill have to look through the paperwork for the prop shaft depth
IMCO boxes can come in a variety of ways...Neutral, 1"-3" raised.....
To get a close measurement, take your outdrive and get it as level to the bottom as possible. Extend a strait edge from the bottom of the boat to the outdrive, then measure down to the propshaft centerline. Mine is now 5", it used to be 8". Depending on the year of you boat yours used to be 6.5 to 7.5" deep.
Here are a couple of threads on X dimension.
http://www.seriousoffshore.com/forum...ight=dimension
PM Ratickle and He'll help you change it.
No Prob !
ok i just got all my part for full hdy. steering .bung in the headers fuel line new pump pressure reg. i will be install soon . can not wait for summer:cheers2:
update on my boat all new gas line 1/2 in new fuel pump and regulator.full hyr. steering.:hurray: and 3000watt boss amp,jbl speakers pioner. sounds great :sifone:going to test this week .
wow i need to take video my boat is running great .ran a few boat this week end and the boat just pull real fast at midrange top speed 81 !at 3500rpm did 55mph very happy so far af reading 13.2 at 3000and at full5500 did 12.6:cheers2:
Get some video up !!!!!!:cheers2:
That is some nice numbers......
ok my best speed 81mph.56oo got to get prop redone .hit something docking the boat i have my cruising prop on and 3200doing 47mph at 4500 doing 70.4 mph 5100doing 78.6mph.
Don't you hate it when you f... up a prop......:banghead::banghead:
ya that prop was perfect . now i am getting it fix and balanceso i hope it comes out perfect. it a 23mirage prop they do not make them now. they make the plus now . my boat likes the old prop
