Lets get a little more info on the Bravo Shops new owner and what future plans may hold. I know us BT guys need a stronger drive since factory merc stuff doesnt hold up that well for us.
John, lets here what makes your stuff greater than the rest
Printable View
Excellent point Chris
1st off it would be the 5" upper gear set.
2nd would be larger shafts
3rd would be internally cooled drive housing
4th new heat treating process on gears and shafts
5th larger bearings
6th would be all new machining process for housings, both upper and lower will be CNC machined to exact spec.
What else would you like to know?
Looks nice John!
Are you doing the billet caps as well?
Yes we have those also.
Glad to hear the specs on your drive.
John, would you agree that now it is a family ran business with your direct involvement and oversight, this will be a much better product than previous. I would think qauilty control and tolerances would be much better than before, especially with your background in machining and fabrication.
Great to hear that it is a family business and I wish you continued success with this venture.
1 more thing to add to the list I have set up a deal with using a power coat that was developed for Caterpillar that will withstand all kinds of chemicals and salt water so all the drives will be getting this process done.
And just so you know it is not Yellow.
Can u do this powder coating to older drives?
Yes that would not be a problem.
Hey guys the new drive temp senders are ready, will get pics up on bravo shop web site in a day or 2.
bump, for all of you BT owners looking for upgrades.
The BT had a lower just stop pushing, no grinding or banging. Might need a little help.
1-800-79BRAVO
What drives do you have?
Are you running stock power?
What props?
The XR is a little lite for the BT you may want to think about something else. We can get smoking deals on new xrs if that the way you want to go!
