Originally Posted by
bcfountain
how do you stop vapor lock in a vst type injection system?the motor is a 502 mag,efi.it uses the early type vst.this is a 1994 motor.i rebuilt the motor last year to stock spec.i did add roller rockers and i had the injectors cleaned and flowed.new mech. pump.the boat always ran rough when idling,but i can deal w/that.now when i run hard for a hour or so and stop for longer than a half hour,the engine will start,idle ok,then go to get on plain,the motor starts to vapor lock.high pressure pump reading on remote gage is about 37psi.it will gage,spit a few times and clear up.wtf?vapor lock?
